Browse Forums General Discussion 1 May 20, 2010 7:59 am We’ve just had the pipes laid for our house and the slab is going to be poured in a couple of days, however I think there is a problem with our pipes. We have 2 toilets going into the house (from the standard plan), but we have also requested a third sewage pipe in the house because we are going to move the toilet in the ensuite after we move in. I was out there this morning and had a close look at all the pipes, but I can’t work out which ones are for normal waste water (sinks etc) and which ones are for the toilets. The worry I have is that the extra pipe we requested has been hooked up to normal waste and not sewage. Can anyone help me work out what pipes are what? Here is a photo of the pipes if it helps Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Current status: Busy making the house our home Built PD Francis 29 on our 576m2 block at Reflections in Tarneit Reflections Estate Thread Our Build Thread Re: Pipes - Help! 2May 20, 2010 9:30 am I'm no plumber but I always thought that sink and shower wastes also go to sewerage? The only things that don't go to sewerage are storm water, or if you have a grey water recycling then you can put some of your wastes to grey water but not shower or kitchen sink. View our blog at: http://room4acubby.blogspot.com/ Re: Pipes - Help! 3May 20, 2010 9:32 am I was under this impression too, does anyone know what the 2 big pipes in the photo are with the drain covers on them? Current status: Busy making the house our home Built PD Francis 29 on our 576m2 block at Reflections in Tarneit Reflections Estate Thread Our Build Thread Re: Pipes - Help! 4May 20, 2010 3:16 pm The 2 larger pipes look like 100mm and would be for your toilets. Arfur Re: Pipes - Help! 5May 20, 2010 3:18 pm This is what I expected, so that means the third toilet pipe that should have been installed is wrong and has been installed as a standard waste pipe. I have my builder looking into it, need to make sure it is correct before the slab goes down Current status: Busy making the house our home Built PD Francis 29 on our 576m2 block at Reflections in Tarneit Reflections Estate Thread Our Build Thread Re: Pipes - Help! 6May 20, 2010 3:36 pm I'm sure your SS will sort it out, but it's a good idea to check anyway, just to be on the safe side. We'd arranged for an extra waste point in the garage, and the plumber doing the under-slab drains missed it. Luckily we did a check count and could see it was absent, so we rang to get it sorted before the slab was poured a couple of days later. BTW, it's only toilets and kitchen sinks that can't be diverted to grey water systems. Showers, baths and laundry sinks are fine. Re: Pipes - Help! 7May 20, 2010 3:38 pm Thanks kek (again ), more great information from yourself Current status: Busy making the house our home Built PD Francis 29 on our 576m2 block at Reflections in Tarneit Reflections Estate Thread Our Build Thread Re: Pipes - Help! 8May 21, 2010 3:45 pm Just got the call to say that they did get it wrong and that the plumber will change the pipe to a sewage pipe in the next few days. Thanks to everyone for their help. Current status: Busy making the house our home Built PD Francis 29 on our 576m2 block at Reflections in Tarneit Reflections Estate Thread Our Build Thread Re: Pipes - Help! 9May 21, 2010 6:33 pm That's great news, wizard. Good job noticing before it was too late! 4 5099 As most others have posted above the install isn't compliant. The pipe is meant to be covered in loose soil or sand, the pipe has holes in it that leaks out a termicide… 10 5704 Building Standards; Getting It Right! Thank you for the generous offer. I need to get the plumber out to give me an explanation. As mentioned I haven't seen any rain water discharge from pipes 1& 3. It… 7 10805 |
