Browse Forums General Discussion Re: Fence removal required for building 150mm from boundaay? 3May 18, 2010 8:49 pm Knockdown and rebuild - building Metr1con Nolan 41 (43) @ http://tim-and-tina.blogspot.com! http://www.verdantdental.com.au Re: Fence removal required for building 150mm from boundaay? 5May 18, 2010 10:46 pm Knockdown and rebuild - building Metr1con Nolan 41 (43) @ http://tim-and-tina.blogspot.com! http://www.verdantdental.com.au Re: Fence removal required for building 150mm from boundaay? 6May 18, 2010 11:04 pm Built a Tribeca 44 with the Big M Sales Accept 15/06/09, Contract Signed 24/09/09, Site Start 23/11/09, Slab 11/12/09, Frame 12/01/10, Roof 20/01/10, Lock-up 30/03/10, Fixing 30/04/10, Handover 27/08/10. Re: Fence removal required for building 150mm from boundaay? 14Sep 12, 2010 4:47 pm ~*~Moved in on the 16th April 2011~*~ Re: Fence removal required for building 150mm from boundaay? 19Sep 14, 2010 7:27 pm und_cvr i cant believe what im reading wouldnt u rather have neighbours that you get along with rather then neighbours that you dont get along with. fair enough if they are buiding over onto your land but if their not tie your dog up for the 2 months MAX that it will take to put down a slab then 1 wall of a garage supervise your kids in those 2 months when there outside and have a healthy relationship with the people you are going to be living next to for years to come who could oneday feed your dog while your on holidays if they are building a home its costing $250,000 minimum, im sure they can fork out $1000 to fix whatever garden bed or plants they damage its becoming a sad sad world that we live in I can't believe what I'm reading either. It's the neighbour causing the disruption and if they want to get along with their neighbours they should cough up for the temporarily fencing. Good grief even when they took out fencing to put deep sewerage through my block they put up temporary fencing for my dogs. Telling someone to tie up their dogs for months is just wrong. You might think it's ok but there are plenty of dog owners who do not, and if you want to get along with your neighbours, you don't expect them to treat their pets this way just because it might be easier and cheaper for the person building Had a new driveway installed with a 6 metre long 150 x 150 channel drain and have since found out it has 4cm of water sitting at the bottom below the side pipe… 0 4735 DIY, Home Maintenance & Repair At a bit of a loss on this one - we're thinking the original owners never removed the protective laminate covers from their kitchen cabinets after installation and in the… 0 6428 Hi, planning on using the attached stone pieces in my bathroom. I want to remove stains and gloss seal. Can I get some advice on best way to remove stains and best… 0 6794 |
