Browse Forums General Discussion 1 May 17, 2010 12:56 pm Hi I am looking at installing an instant hot water unit the runs on lpg. Can anyone help, with their experience , I am looking at a bosch 16h hydropower, as it needs no power to be run to it to operate pilot light. The area I live in has no natural gas and LPG storage units make hot water very expensive. Any other ideas would be considered. Thanks Rob Re: Instant Hot water on LPG. Bosch 16h 2May 17, 2010 8:35 pm I have LPG ... I have Rheem solar with the gas booster ... I also use the gas for my stove top ... has been 6 months now and I'm still on the first bottle (only one person in the house tho). Re: Instant Hot water on LPG. Bosch 16h 3May 17, 2010 9:41 pm ghoulie1 Hi I am looking at installing an instant hot water unit the runs on lpg. Can anyone help, with their experience , I am looking at a bosch 16h hydropower, as it needs no power to be run to it to operate pilot light. The area I live in has no natural gas and LPG storage units make hot water very expensive. Any other ideas would be considered. Thanks Rob We put one of those in the shed we converted to temporary living quarters while we built. I understand it is too small to cope with a multi-bathroom house, but it was fine for our purposes. Works flawlessly and instantly even with the very occasional use it now gets. The lack of a need to provide it with a power point was a big bonus for us. It provides much hotter water than the Rinnai 26 in the new house. I guess this is a "settings" thing, though. The house one can be tweaked with jumper switches to provide water at a higher temp, but we've resisted this due to insurance legalities. The small shed unit came set at the higher temp from the factory. Cheers zeke I am installing a new Bosch SMU4HTS01A built under dushwasher. I have 2 questions. What is the function of the metal strip about 500mm long x 60mm wide the tell you to… 0 2707 the sun master is the solar heating to "warm" the water in the tank the S26 is your hot water system which will heat the water (25 degrees?) so with both turned on you… 2 14041 I want to build a decking to the drawn shape outlined in black. The problem is how close can I build to the gas hot water unit? Will I be able to build around it and be… 0 20230 |
