Browse Forums General Discussion 1 May 14, 2010 12:48 pm I'm assuming this is spam? Same post, posted on multiple forums within 12hours ---------------------------------------- Building the PD Lisbon 24 http://www.porterdavis.com.au/#homeviewer/lisbon/24 Blog of our progress. http://lisbon24.blogspot.com/ Homeone build thread https://forum.homeone.com.au/viewtopic.php?f=31&t=28665 You should pressure clean your roof first and make sure the paint you buy also is anti mould. 4 18953 Building Standards; Getting It Right! 1. optional, you can but normally just use the earth from the main switch board 2. should be enough but the distance determines voltage drop - sparky should work it… 1 28879 |
