Browse Forums General Discussion Re: colourbond garage/shed questions 15May 14, 2013 2:05 pm Like others our new shed 16L x 9W x 3.6H went on the slab rather than poured inside. All our columns are RHS 100x150 with base plates. Holes were drilled in the slab and bolts placed in with Chemset adhesive. The cladding comes down slightly past the slab. We filled the gaps with expanding foam and have no rodent problems. One thing to remember with pouring the slab later, is that if you need the 3m height in your shed ( ie caravan or similar access) your doorway access will be reduced by up to 125mm. So your doorway may only 2.6 or thereabouts in height. Also sliding door access will give greater height than a roller door. Settlement 1/2/12 New Shed 23/3/12 Slab poured 27/3/12 Frame complete 4/5/12 Roof complete 1/6/12 LOCKUP 29/6/12 Our new build blog http://kareenhillsownerbuild.blogspot.com/ DIY, Home Maintenance & Repair Hi all I've got a brick garage/shed at the back of my house. It's been hit at some point (before I owned it) and has a large crack running down through the bricks. I want… 0 826 Hi Our backyard colourbond fence located on a busy road and it wobbles when cars drive pass it and when it is windy as well. It's colourbond and with 8 posts concreted… 0 2021 Yes i guess this is one of the main reason as i checked one post foundation 4 8566 |
