Browse Forums General Discussion 1 May 05, 2010 12:21 am Howdy, Am looking at the my plans for the master bedroom which includes a rectangular walk in robe with a door at each end (one to the bedroom and one to the ensuite). With 60cm allotted either side for the shelves and hanging space, is 90cm as the aisle an ok width or is it too narrow? Building tip No. 3: A raft slab will not get you down a river. A waffle pod slab does not go with maple syrup. My building thread https://forum.homeone.com.au/viewtopic.php?f=31&t=53000 Re: width of walk in robe section 2May 05, 2010 8:57 am 90cm or 900mm is an adequate size. think of a doorway opening which would typically be 82cm wide so you'll have a further few cm bigger. "I never learned a thing until I finished school" - Unknown "You can get anything accomplished, If you don't mind who gets the credit" - Ned Hay Re: width of walk in robe section 3May 05, 2010 10:10 am We allowed 1400mm for our walk in robe ie. 600 wide shelves and 800 to get access. It's not a true walk in robe where you'd get changed in it but just a neater option than a wall of panel doors. There's a 720mm entry door at one end We lose some bedroom space but get a wall instead of a row of doors that we cant put anything against. The 800 width should allow plenty of room to get in and get stuff out. Edit : It's the WiR in the master bedroom. http://img72.imageshack.us/i/proposedhouse.jpg/ Re: width of walk in robe section 5May 05, 2010 2:41 pm Thanks guys, Have been considering reducing it to 800 to get a bit more room in the main bathroom and you guys have sold me. Building tip No. 3: A raft slab will not get you down a river. A waffle pod slab does not go with maple syrup. My building thread https://forum.homeone.com.au/viewtopic.php?f=31&t=53000 Thanks again for this information. If you do hear anything different, would be great to know 4 8256 Any structural alteration to your home requires building permit. Before you get it you will have to supply plans with structural assessment, you will also be removing… 2 4139 Do you really want to accommodate the window? What is on the outside of the window? Do you want to be able to see your towels from outside? I would blank the window from… 2 8410 |
