Browse Forums General Discussion 1 Apr 18, 2010 2:38 pm Hi all, Just a few questions on what is the norm for a few items that concern me that I want fixed before the hand over. date. The first - is in the Landry. On top of at the end of the bench at the back under the tile against the wall, there is no silicon and there for a gap for water to seep into. Does this need to be fixed ? Second - Is in the Landry again but between the skirting tiles and under the cupboards there is no silicon and there a good 0.5cm cap for water to seep into. Does this need to be fixed ? Third - Is in the main bathroom. Where tiles on two walls are meant to meet but one is short by 0.5cm all the way down the wall, so instead of tiles meeting at the corner there is a 90 degree cut out so to speak on that corner. Can and Should I get them to fix this. Forth - Is in the Theater room. Where I have installed two cavity doors, but the doors are to small for the door way leaving a gap of 3cm on the end of the doors. How will I get them to fix this, as I don't want just a ******* bit of wood nailed onto the exciting door way. It also falls off the guide when fully closed. Cheers for any help J. Re: Questions Before Handover 2Apr 18, 2010 3:09 pm Yes get them to fix them all. The gaps you suggest be filled with silicone to prevent water entry are virtually a no cost item. The tile gap - can that be filled with the grouting used elsewhere on the tiling? If so get them to fill that, other wise it would be rip all the tiles off and relay them so the corners meet each other - and this will probably have a worse outcome than an extra wide grout fill. But the door gap seems to me as it might be an obvious flaw for you to detect to divert you from seeing some other major flaw that might be hidden but you just haven't seen it yet. And yes, certainly get them to fix that. Cheers Ardo That is so funny! I wonder how many people know who Larry Haun is these days. I have a couple of young guys we call Mo 1 & Mo 2 who run a crew of 6 boys and… 9 12917 You should check your detail drawings, it may show downpipe within brick pier. 14 8590 Thanks for info, yes met with Power Utility, Builder's Site Supervisor and Electrician on site and aligned on the mains connection. Seems like the builder and Electrician… 2 10031 |
