Browse Forums General Discussion Re: What is Base infill? 2Apr 19, 2010 3:54 pm Must be a reference to the site works, fill / level or soil stabilisation ? yep you need a joint, foam is easiest, will look fine once rendered with a joint. 2 5236 I've filled, levelled and compacted around 100mm of roadbase in preparation to lay some outdoor court tiles. Prior to doing the final compaction, I dusted the top with… 0 3047 I have seen poly marble shower bases last in excess of 30 years 1 4510 |
