hi
just a quick question
situation - wanting to put up walls in garage. will need wood frames for insulation and plasterboard.
i'll need treated pine for termite protection, but do i need structural or non structural pine?
other than the weight of insulation and plasterboard, they won't be load bearing (unless shelves count?)
thanks
You don't neccessarily need structural, however I would use structural...straighter and better quality...
wouldn't cost a lot more either.
And you may not need insulation either.
Typically the walls of a garage are not lined with insulation. Studies have shown negligible benefit gained by adding insulation to the internal walls (between garage and habitable rooms). There is sufficient air space contained within the garage itself to provide thermal insulation.
However, you are more than welcome to add insulation if you want too. It may make you feel better about it and the manufactures wouldn't mind either.
really?
thats definitely news to me
a single brick wall garage has sufficient insulation to not need anymore??
maybe i should specify that i wish to make the garage something of a 'games or man's room' to drink, play pool and hang out in to late in the morning
this is a quote taken from the insulation page of yourhome.gov.au
Quote:
Brick Veneer walls have the brick skin on the outside, which is not the ideal location for thermal mass. The bricks heat up in summer and radiate heat late into the evening, while in winter they stay cold and absorb heat from the house. Insulation is essential to protect the occupants from external temperature extremes that are exacerbated by the external brick skin.
I think there are some crossed messages regarding insulation here. You do not necessarily to insulate the garage as this room is not considered habitable, the air mass in the garage and the walls surrounding the garage offer effective insulation to the next layer of the house, therefore it may not be necessary to insulate the walls between the garage and the rest of the house. If you are converting the garage to a habitable room or even a blokes room, I would definitely suggest insulation, otherwise you will need to drink more beer in winter to stay warm there.
Joists under shower trayGeneral Discussion
Hi All, about to commence a bathroom renovation and need some advice on subfloor works.
Current subfloor is hardwood T&G floorboards on 90x45 joists, but intention is to…
