Browse Forums General Discussion 1 Apr 14, 2010 2:33 pm Hi all I am loviing this forum its been fabulous for inexperienced renovators like me! We have just bought a 1960s brick veneer house in Bayside Malebourne and are planning on doing a fairly large reno. Removing Walls ( pretty sure they are structural) new kitchen including changing tap from wall to island bench new bathroom same layout new ensuite enclosing porch building garage removing carpet/lino sanding and polishing the hardwood floors PHEW So would love some opinions ideas and comments on our ideas/plans so far here (hopefully it works) is the exisiting floorplan Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ ************* First time renovator VIC Re: First time renovator desperate for advice and ideas 3Apr 14, 2010 5:13 pm Hi Im removing the one between kitchen and dining and also between kitchen and laundry. But hoping we can use beams to support to ahve an open plan feel Candi ************* First time renovator VIC Re: First time renovator desperate for advice and ideas 4Apr 14, 2010 6:11 pm candice.novak Hi Im removing the one between kitchen and dining and also between kitchen and laundry. But hoping we can use beams to support to ahve an open plan feel Candi Good idea - that should work well and will really open the house up. Re: First time renovator desperate for advice and ideas 5Apr 14, 2010 6:50 pm We are also half way through renovating our house. Getting rid of walls can make such a huge difference. All i can say is that it will take you about 3 times as long as you think. We polished the floors ourselves as well and that was really hard work and never again. I would just pay someone. They did come up really well though. Good luck. Re: First time renovator desperate for advice and ideas 6Apr 14, 2010 8:24 pm thank you very much in panic mode now as only have 5 weeks to plan and design renos settlement extension is now not an option! Candi ************* First time renovator VIC Can anyone give me any onfo on New Homes WA? Good or bad, hopefully good just need to know if my choice was good or not? Thanks ❤️ 0 8933 So it looks like we finally have some movement on site! Definitely later than expected, but I'll take any progress at this point. I'll drop by over the weekend to get… 5 27071 Versaloc is a mortarless besser block system that still needs a properly engineered footing. If you just do a 400x200 footing it will fail in time. At 17m long you need it… 1 15563 |
