Browse Forums General Discussion 1 Apr 11, 2010 11:06 pm Hi All Pondies lol. Can someone please shed some light on what this calculation really means.. It says on the design checklist. Planning your house Building Area max 40% (Site>550msq) Landscaped Area min 45% (Site>550msq) Our lot falls in the >550msq however when we multiply the % as per what this is saying it basically says we can build a 26sqm house that seems bogus to us Thanks for the info.. pretty sure we are not "understanding the above calculation" http://dreamzattheponds.blogspot.com To be invited to our blog send a PM with your email. Settled on land 25th June Exchanged contracts on Land April 14th 2010 Building our First Home Re: Confused about Design Guidelines at the Ponds.. 2Apr 12, 2010 6:43 am This is the footprint of the building. For blocks this small the only way to have a 30sq+ house is to go two storeys. View our blog at: http://room4acubby.blogspot.com/ Re: Confused about Design Guidelines at the Ponds.. 3Apr 12, 2010 9:27 am Are you building single or double? The PDRP guidelines V 2 (with the picture of the kid on the bike on the cover) has the info set out on Page 9. For single it can be 50% and for double its 45%. To work it out you need the sqm (not SQ) of the footprint, so ground level only on double, then work it out. EG 250sqm footprint / 550sqm land * 100 = 45% They will consider designs outside this and any alfresco or coutyard can be considered as part of your private open space. Min Building at The Ponds Land reg 3/12/09, Land settled 18/12/09 Approved by Design Panel 16/11/09, Submitted to council 24/11/09, Approved by Council 21/1/10 Site Start 21/5/10 http://andyminpondsbuild.blogspot.com/ https://forum.homeone.com.au/viewtopic.php?f=31&t=19800 Re: Confused about Design Guidelines at the Ponds.. 4Apr 12, 2010 12:57 pm Thanks andy guess we are mainly confused with the squares. For example we went witha builder they informed us we have 238smq. we where able to fit maximum i think a >55 square house. Ohhh nowwww i get itttt.. The first floor only!!!! and the line i have written above is including the whole house for double story loll.. thankss i finally get it heheh our land size is 595squares 17 frontage and back sides 36 and 34 No easements, no sewerage structures.. which is why the above calc confused me. silly me lol http://dreamzattheponds.blogspot.com To be invited to our blog send a PM with your email. Settled on land 25th June Exchanged contracts on Land April 14th 2010 Building our First Home Re: Confused about Design Guidelines at the Ponds.. 5Apr 12, 2010 1:11 pm On our plans it shows the ground floor area listed separately as 161sqm. Then our first floor, garage and alfresco are listed separately. So I think for design submission we referred to this number as the footprint size, I don't remember if we included our garage for submission. So ours worked out at about 33% for a 40 SQ 2 storey and our pool was also considered as part of our Private Open Space. Building at The Ponds Land reg 3/12/09, Land settled 18/12/09 Approved by Design Panel 16/11/09, Submitted to council 24/11/09, Approved by Council 21/1/10 Site Start 21/5/10 http://andyminpondsbuild.blogspot.com/ https://forum.homeone.com.au/viewtopic.php?f=31&t=19800 Re: Confused about Design Guidelines at the Ponds.. 6Apr 12, 2010 7:02 pm cool. can be tricky.. but get it now.. cheers http://dreamzattheponds.blogspot.com To be invited to our blog send a PM with your email. Settled on land 25th June Exchanged contracts on Land April 14th 2010 Building our First Home Re: Confused about Design Guidelines at the Ponds.. 7Sep 23, 2010 8:30 pm andy_min So ours worked out at about 33% for a 40 SQ 2 storey and our pool was also considered as part of our Private Open Space. Does anyone know if the Alfresco is considered part of principle POS? If we have our living area opening into Alfresco at back and then rear garden behind that, would this be ok to satisy 4mx6m requirement for principle POS? ------------------------------------------------------- http://homeinkalina.blogspot.com Enjoying our new Concerto with Allworth Homes in Kalina, The Ponds Handover - 28/06/2011 If this is a custom build then I would expect the builder to set out the door frame closer to the wall to avoid the gap between architrave and the wall and or specify… 9 8289 Thank you so much for the effort. We will use it to talk with builder. We also had idea of building duplex instead and seeking suggest ions. viewtopic.php?f=31&t=106744 11 13817 Once you know the basics, the rest is easy. Read my post in the thread linked below. viewtopic.php?p=1919271#p1919271 2 19497 |
