Browse Forums General Discussion 1 Apr 11, 2010 5:45 pm I was wondering if anyone has/or has seen pictures of any modern verandas using corrugated iron? I am looking at replacing a veranda with a semi circle shaped corrugated iron design. Im not sure if i will need to have a frame welded up to support this or whether I could get just once piece manufactured to cover 3 metres and just use 4 supports? I have looked on the net for a modern veranda but have had no luck. Any help/opinions are appreciated. Cheers Is it possible to render an old corrugated iron shed.I have heard that it can be done if it is covered with chicken wire first.Not sure of the ratio of the render mix and… 0 4896 i think option 2 is much better with easy access to the garden without having to walk through the new sunroom which makes it a better room for guests and TV .a simple… 2 8227 There may be answers here but can't find anything. I have a closed in veranda, four windows. North facing, just had sunblock blinds installed. A bit cooler (actually… 0 2978 |
