Browse Forums General Discussion 1 Apr 06, 2010 9:21 pm We are considering getting a gas boosted solar hot water system for our new house. We are not sure whether we should choose a roof-mounted tank or a tank on the ground. I you have installed such as system we would be interested to know what are the pros and cons of roof versus ground tank. Some pros and cons we can think of are: Roof mounted: * may need roof reinforcement (extra cost for house building?) * look bulky on the roof Ground mounted: * includes a small electric pump to circulate water up to the solar panel - pump consumes electricity, it can fail Re: Solar hot water system - tank on roof versus tank on gro 2Apr 07, 2010 8:40 am The biggest issue is maintenance. If something does go wrong, it is a hell of a lot cheaper to have someone on the ground fix it than someone on the roof fix it. The cost to reinforce the roof to take the load of a tank is more than the cost of a small concrete pad for a tank on the ground to sit on. Tank on the ground can be easily placed out of site or surrounded by a timber wall/cladding feature. A tank on the roof cannot be easily hidden like that. "I never learned a thing until I finished school" - Unknown "You can get anything accomplished, If you don't mind who gets the credit" - Ned Hay the sun master is the solar heating to "warm" the water in the tank the S26 is your hot water system which will heat the water (25 degrees?) so with both turned on you… 2 14171 The tank is around 200 litres (I am on holiday for the next 6 weeks so can't check) The Heat Pump has a built in time switch. No idea on the speed to heat because with… 6 2555 I want to build a decking to the drawn shape outlined in black. The problem is how close can I build to the gas hot water unit? Will I be able to build around it and be… 0 20321 |
