Browse Forums General Discussion 1 Apr 06, 2010 3:46 pm Re: Deep Floating Shelves 6Apr 06, 2010 7:10 pm Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: Deep Floating Shelves 14Sep 07, 2010 11:18 am xanthrope Deep floating shelves are great to look at, but bear in mind that they do not reach their full load bearing capacity unless fitted into solid brick walls. Please ensure that you include at least 1 stud in your load bearing section. I know tht houses now-a-days are built with a stud spacing of 600 mm between centers. You would need to be careful about where you locate your screws. You sure do... Basically. If the shelves are fixed then they will be screwed in just the same as the rest of the carcass. To re move the screws you need to remove that section of… 3 5215 Thanks Simon, I guess I'm no concerned with the volume of the noise rather that dead and hollow sound and feel that is associated with floating floors. But I'm not sure… 3 6164 Thanks, that's the motivation I needed to give it a try sooner rather than one day! 4 3019 |
