Browse Forums General Discussion Re: The Ponds - Land Release 222May 19, 2010 10:29 am Building at The Ponds Land reg 3/12/09, Land settled 18/12/09 Approved by Design Panel 16/11/09, Submitted to council 24/11/09, Approved by Council 21/1/10 Site Start 21/5/10 http://andyminpondsbuild.blogspot.com/ https://forum.homeone.com.au/viewtopic.php?f=31&t=19800 Re: The Ponds - Land Release 226May 19, 2010 3:33 pm Building at The Ponds Land reg 3/12/09, Land settled 18/12/09 Approved by Design Panel 16/11/09, Submitted to council 24/11/09, Approved by Council 21/1/10 Site Start 21/5/10 http://andyminpondsbuild.blogspot.com/ https://forum.homeone.com.au/viewtopic.php?f=31&t=19800 Re: The Ponds - Land Release 227May 19, 2010 3:49 pm Thank you very much. You have cleared my doubt. My sister has another lot which slopes 1m to the street but there is a swere structure in in her land. Is is a visible structure. As you can see we are very new to thi concept. What about the price? Is it a fair price given the current sale price at the Ponds? regards andy_min You could consider making the house split level too. But I also think you will need more $$. If there is another block you like you can change your preference to something else available when you go on Sat. Re: The Ponds - Land Release 228May 19, 2010 4:04 pm Hi acpn.. Another thing you'l consider is that calculating the actual footprint, after setback at the back, front and sides, the fall will become lesser... I reckon the price is allright considering the average price and the size of the lands... Re: The Ponds - Land Release 229May 19, 2010 4:06 pm Its cheaper than the previous Waterfall releases but without knowing how many sqm its hard to say. What lot number is it? Building at The Ponds Land reg 3/12/09, Land settled 18/12/09 Approved by Design Panel 16/11/09, Submitted to council 24/11/09, Approved by Council 21/1/10 Site Start 21/5/10 http://andyminpondsbuild.blogspot.com/ https://forum.homeone.com.au/viewtopic.php?f=31&t=19800 Re: The Ponds - Land Release 231May 19, 2010 4:19 pm How do I go about calculating the footprint? regards Linor501 Hi acpn.. Another thing you'l consider is that calculating the actual footprint, after setback at the back, front and sides, the fall will become lesser... I reckon the price is allright considering the average price and the size of the lands... Re: The Ponds - Land Release 232May 19, 2010 4:28 pm acpn2330 How do I go about calculating the footprint? regards Linor501 Hi acpn.. Another thing you'l consider is that calculating the actual footprint, after setback at the back, front and sides, the fall will become lesser... I reckon the price is allright considering the average price and the size of the lands... What is the size of your land and the size of the house your thinking of building? It can only be calculated upon the size of the house you wanna build... Re: The Ponds - Land Release 233May 19, 2010 4:36 pm The land size is 450 and the building is 27sq. regards Linor501 acpn2330 How do I go about calculating the footprint? regards Linor501 Hi acpn.. Another thing you'l consider is that calculating the actual footprint, after setback at the back, front and sides, the fall will become lesser... I reckon the price is allright considering the average price and the size of the lands... What is the size of your land and the size of the house your thinking of building? It can only be calculated upon the size of the house you wanna build... Re: The Ponds - Land Release 234May 19, 2010 5:35 pm Hi acpn, I agree with others comments regarding the construction budget. Our site costs were 10k extra, you might also have extra expenses on your fascade to make it comply with The Ponds dcp. If you have a drop edge beam also (because of the fall on your block) this will also cost extra. As others have commented as well, if your house footprint is smaller, the likelihood of needing this is reduced. Re: The Ponds - Land Release 235May 19, 2010 6:25 pm hi all I took a priority number for 15m wide and 30m long rectangular plot at blackthorn...... but there is a fill on the land.Any idea how will it impact and how much extra???????? please advice. thanks Re: The Ponds - Land Release 236May 19, 2010 7:00 pm http://www.landcom.com.au/downloads/Fil ... ummary.pdf acpn & missionhome check this out its a summary of the design guidelines and can help you cater a house that will suit your land etc.. http://dreamzattheponds.blogspot.com To be invited to our blog send a PM with your email. Settled on land 25th June Exchanged contracts on Land April 14th 2010 Building our First Home Re: The Ponds - Land Release 237May 20, 2010 9:08 am acpn2330 The land size is 450 and the building is 27sq. regards Your footprint will be 27 squares then...it's actually the total amount of area of concrete... however, excluding your driveway... another tip: The Building Area is the area enclosed by (and including) the walls. It does not include open porches, alfresco, verandah areas, or paved areas like a driveway or path. Re: The Ponds - Land Release 238May 20, 2010 1:09 pm Acpn- Quote: it is Lot 198 and my sister in law is lot 205. Lot 205 looks good for your SIL as the sewer runs through the front of the block. The sewer access point is a flat manhole concrete thing that they use if they need to get in. The only impact it might have is which side the driveway can go on. Lot 198 is a bit trickier. You have the sewer line running through the back of the block meaning you cannot build within 1.5 metres of it and depending how close your house is to it you may need to have additional foundation measures such as additional piering or sewer encasement. add to that the block sloping backwards and its looking like quite expensive in terms of site fees. I couldnt find a plan of the Ascot (I think that what you were going to build) showing the the depth, so taking a guestimate from the room sizes on the floor plan it looks to be about 23-25metres deep + the 4.5m front setback puts you very, very close to the sewer easement. It you were building that house on Lot 205 Mosaic, it should fit OK. Missionhome- Quote: but there is a fill on the land.Any idea how will it impact and how much extra???????? You will need to budget for a H class slab which includes piering. The cost varies from builder to builder and there is another thread on here about ponds site costs if you search for it. Just about every block has fill of some form so its very common. Good Luck Min Building at The Ponds Land reg 3/12/09, Land settled 18/12/09 Approved by Design Panel 16/11/09, Submitted to council 24/11/09, Approved by Council 21/1/10 Site Start 21/5/10 http://andyminpondsbuild.blogspot.com/ https://forum.homeone.com.au/viewtopic.php?f=31&t=19800 Re: The Ponds - Land Release 239May 20, 2010 4:03 pm andy_min You could consider making the house split level too. But I also think you will need more $$. If there is another block you like you can change your preference to something else available when you go on Sat. hi andy do you know anything about landfill? how much extra???????? thanks Re: The Ponds - Land Release 240May 20, 2010 4:29 pm Quote: do you know anything about landfill? how much extra???????? That can depend greatly but it would be in the $ thousands unless you can get someone to drop off free clean fill for you. Even then it still needs to be compacted. Building at The Ponds Land reg 3/12/09, Land settled 18/12/09 Approved by Design Panel 16/11/09, Submitted to council 24/11/09, Approved by Council 21/1/10 Site Start 21/5/10 http://andyminpondsbuild.blogspot.com/ https://forum.homeone.com.au/viewtopic.php?f=31&t=19800 Yeah I don't know why I came to a forum. Place is full of wierdos/pedos thought internet may help but I suppose I'll try my luck with someone in person. Cheers. I tried… 0 6442 Need advice on the backyard plan above. Should I excavate and cut all of the dirt to level with the house slab or semi-excavate as per photo above? Both left and right… 0 24863 13 6632 |
