Browse Forums General Discussion Re: VOIP? ADSL2? Naked DSL? Have I been in hybernation? 3Mar 27, 2010 4:04 pm Where you are coming from is where you are going to... Re: VOIP? ADSL2? Naked DSL? Have I been in hybernation? 6Mar 27, 2010 9:13 pm 'A bottle of wine contains more philosophy than all the books in the world.' Louis Pasteur Vegie garden: viewtopic.php?f=19&t=27637&start=0 My Backyard Adventure Re: VOIP? ADSL2? Naked DSL? Have I been in hybernation? 7Mar 28, 2010 11:30 am ---------------------------------------- Building the PD Lisbon 24 http://www.porterdavis.com.au/#homeviewer/lisbon/24 Blog of our progress. http://lisbon24.blogspot.com/ Homeone build thread https://forum.homeone.com.au/viewtopic.php?f=31&t=28665 Re: VOIP? ADSL2? Naked DSL? Have I been in hybernation? 13Mar 29, 2010 4:18 pm Lara and Joshua http://pdheywood25.blogspot.com/ viewtopic.php?f=31&t=31186 16.03.10 Scrape 29.03.10 Slab 08.04.10 Frame 11.05.10 Lock Up 03.06.10 Fixing 24.08.10 Handover Re: VOIP? ADSL2? Naked DSL? Have I been in hybernation? 16Mar 30, 2010 5:23 pm Yes, you can easily switch between plans, even while in contract. You can't sign up with Primus on the Max plan, as it is only available for existing customers, but if you sign up for a different plan, you can then change to Max within the first couple of months. Before signing up, make sure you check that you can get ADSL2+ on the Primus website service checker. If you cannot get ADSL2+ plans, Max will not be available to you. Lara and Joshua http://pdheywood25.blogspot.com/ viewtopic.php?f=31&t=31186 16.03.10 Scrape 29.03.10 Slab 08.04.10 Frame 11.05.10 Lock Up 03.06.10 Fixing 24.08.10 Handover You have mandatory building inspections and privately engaged building inspections. The difference between the two comes down to inspecting the building so it's safe and… 3 18025 Hello everyone, I have a question regarding moving a chandelier after it has been mounted. The chandelier in question is quite large, measuring 4 meters… 0 72313 6 11528 |
