Browse Forums General Discussion This is 100% true. You can not hang anything on steel frames. very frustrating 8 8052 Would also like an opinion from anyone that has used xcem over hebel for floors. Thanks 1 14248 Building Standards; Getting It Right! 1. optional, you can but normally just use the earth from the main switch board 2. should be enough but the distance determines voltage drop - sparky should work it… 1 28821 |
