Browse Forums General Discussion 1 Mar 24, 2010 9:44 pm Hello people, from Mangos husband,
We have an elevated home in the far north of Australia. We have just embarked on another project (one more in the long line of projects that get between me and barra fishing), enclosing half the underhouse area for a unit. I will be welding up frames any day now, just have to finish off some of the fiddly bits first. On the relevent part of my plans I have the notation, "corrosion resistant paint or moisture proof membrane under all wall frames" which means to me between the bottom plate and the concrete slab. I was thinking of bitumum paint or that nylon type material that usually water proofs around windows, Anyone got suggestions or recommendations on what other product might suit? Re: Steel frame on concrete, what corrosion preventions? 2Mar 24, 2010 9:51 pm There are liquid applied membranes or your could just use sheet waterproofing membranes. The 2 different surfaces (concrete & steel) forgive me if you realise, have different thermal creep and is abrasive to surfaces, beginning corrosion. You are on the ticket by providing a barrier. Where you are coming from is where you are going to... Re: Steel frame on concrete, what corrosion preventions? 3Mar 24, 2010 9:54 pm Normal bricking damp-course is what is used on most steel frame houses. (in SA anyway) good luck with the barra Land settlement 4 May Building contracts signed 27 July Slab pour 26 March Frame started 10 May Bricks start 31 May Roof & Gutters Start 31 May gyprock 1 July Kitchen & cabinets/tiling 19 August Second fix plumbing 15 September Second fix electrical 22 September PCI 28 September viewtopic.php?f=31&t=29155 Re: Steel frame on concrete, what corrosion preventions? 4Mar 24, 2010 9:58 pm Thanks for the quick reply to you both, I think I will end up going with the damp course that way I can run it up the interior a couple hundred mill to stop water egress, Be good Re: Steel frame on concrete, what corrosion preventions? 5Mar 24, 2010 9:59 pm Yes... but this time the job is in the tropics. A tad more rain and a heap more humidity Where you are coming from is where you are going to... Re: Steel frame on concrete, what corrosion preventions? 6Mar 24, 2010 10:08 pm Mmmm and that occasional driving wind too (cyclones). I was looking actually at a combination of both methods, esp under and around doors, Oh and building aimlessly they are having a good season on barra, me, mutter mutter growl growl, I wouldnt know from first hand experience this year mutter mutter... Re: Steel frame on concrete, what corrosion preventions? 7Mar 24, 2010 10:09 pm Egress is the way out - ingress is the way in Where you are coming from is where you are going to... Re: Steel frame on concrete, what corrosion preventions? 9Mar 24, 2010 10:57 pm Is good, no??Yes yes yes No! A weather apron is a good idea.. but what do you do at door ways? Well that is why we have a step up AULL Onc Where you are coming from is where you are going to... Re: Steel frame on concrete, what corrosion preventions? 11Mar 24, 2010 11:27 pm Where you are coming from is where you are going to... Hi I am wanting some opinions about the build of a steel shed I am going to get one about 4.5 x 2.5 m steel shed and the height will be about 2.3-2.4m high The one I am… 0 14435 This is 100% true. You can not hang anything on steel frames. very frustrating 8 5354 Hi, I have a steel frame house which was built 2 years ago. When you are down stairs you can hear clunking noises when someone is walking around. We were told if you… 0 4441 |
