Browse Forums General Discussion 1 Mar 23, 2010 10:22 pm The render on our house started today, problem is they have render more area on our faced then what is on the plan. This will ruin the look on our facade.
Only the first layer of render has been done so far. Can render be remove without re-doing the brick, is it possible to was away the render? Re: POssible to remove render without redoing the bricks? 2Mar 23, 2010 10:27 pm Wash away the render?! No I do not think you can unless something new that I do not kow is out there. You have just have to scrape it away and the sooner the better This certainly doesn't look good. I would be engaging with an independent inspector to have a look at this. As for the unscheduled site visits, most builders are quite… 1 28598 Elvis has left the building... The site supervisor quit after 2 month on the project. I guess he was just instructed to bark at people, but didn't like when he was… 26 21107 Hi, I contracted a Builder to do a Garage to Bedroom + ensuite conversion (Class 1a), the Builder engaged the Certifier and Engineer and received BDA from the Certifier… 0 5422 |
