Browse Forums General Discussion 1 Mar 22, 2010 9:41 pm .. this was a real concern for me. I needed to remove two UPVC cemented pipes from a $1.5k sand filter ready for a rebuild (the multiport valve was being replaced with an electronic one). I was told it couldnt be done (well, pretty much no endorsement from everywhere I could seek info). Some said to pour glue into it and light it up and let it burn for a while, then see if you can pull it out. Well, as it turns out, the trick is to use an electronics heat gun, slice the pipe insert and heat. The male pipe insert will just fall out with a bit of a tug from a pair of long nose pliers. .. now - to rebuild my pool pump pad and get the vac running. http://users.tpg.com.au/srkh//pvchere.JPG http://users.tpg.com.au/srkh//pvcgone.JPG steve Hi, it comes down to a few things - Durability, looks and cost. Generally, iron fences are more durable due to the fact they are resistant to pests and rotting but are… 1 16464 3 4170 4 5117 |
