Browse Forums General Discussion 1 Sep 03, 2007 10:12 pm Looking to put solar hot water into my new place.
There's the evacuated tube type made by Endless Summer. Apparently more efficient and reliable than flat panel systems, however cost is almost double. On their website, they mentioned that flat panel systems contains chemicals that degrade overtime and will eventually lose efficiency and need to be replaced. Just want to hear from people who has the flat panel type for a while to see what their experiences have been. Also, want to hear from people in colder parts of Australia (Vic / Tas) how well solar hot water works in winter. Does the sun provide enough heating to not need boosting? Any comment appreciated. Re: Solar hot water 2Sep 05, 2007 7:46 pm This will give you an idea of the savings.
http://www.sv.sustainability.vic.gov.au/renewable_energy/policies_and_initiatives/shw/why_choose_shw.asp and this one compares various units performance. http://www.eeca.govt.nz/eeca-library/renewable-energy/solar/report/swh-performance-evaluation-2004.pdf Steve the sun master is the solar heating to "warm" the water in the tank the S26 is your hot water system which will heat the water (25 degrees?) so with both turned on you… 2 14045 I want to build a decking to the drawn shape outlined in black. The problem is how close can I build to the gas hot water unit? Will I be able to build around it and be… 0 20230 DIY, Home Maintenance & Repair Hi, I've got a brand new (2nd hand) Bosch Hydropower 16H tankless hot water heater. Since it was installed I have noticed it leaks a lot. I took the cover off and it looks… 0 24147 |
