Can anyone recommend a structural engineer in Sydney to see if a wall can be removed in a strata unit?? Has anyone had an internal brick wall removed if so what was the approx cost.
Reply
Sign in or Join to reply to this Topic
End
Page 1 of 1 ⋅ 1 post
I understand and agree to the TERMS OF USE and agree that this post satisfies these rules.
The engineering is the engineering. It's irrelevant how much material you have. Unless it fits the requirements of your design the engineer can't "make"it work.
You might…
Assuming you've modelled the TB8, TB10, TB12, TB2 & J1 joists/LVLs there, it appears as per drawing to me.
There maybe should be an additional J1 between TB10 and T12 if…
interesting situation
what happened after builder issued final invoice? did you list as defect or not
does the building surveyor have any responsibility? ie. issuing…
