Browse Forums General Discussion 1 Mar 15, 2010 1:03 pm We had our vanities installed on friday and I noticed that the sink was put in the spot next to the wall (less than 10cm away making it useless for toothbrushes and hairdryers) apparently the cabinet makers didnt have the electrical plan and vice versa and I thought the drawers were going on the other side like the display home (and thats what I asked for) but missed it on the plan when I checked it. are there any regulations about how close a pp can be to a sink? i really want it changed and am trying to work out if we should be the ones to pay for it or the caninet makers? Here is a drawing of what it looks like Lauren and Tony: Building our first home in the Vaucluse estste, Doreen, Melbourne http://laurenandtonyshouse.blogspot.com/ Quote of the Day: "I know what you wanted but I did it this way becausee I thought it would look better" Re: Powerpoint directly next to the sink? ok or not? 2Mar 15, 2010 1:17 pm there are definately regulations on this one. From memory I think that a pp or light switch cannot be less than 15cm from water outlet. Better check that fugure though. You may have problems getting certification for this one. progress viewtopic.php?f=31&t=20401 sculptures viewtopic.php?f=36&t=26607 pole trouble viewtopic.php?f=3&t=25988 Re: Powerpoint directly next to the sink? ok or not? 3Mar 15, 2010 5:47 pm I don't know how accurate this is (found it on a renovation reference site), but it sounds about right from memory: Quote: Where sinks have a capacity of less than 20 litres, the area within which a power point or switch cannot be located is 40mm in height and 150mm either side of the sink basin edge. Re: Powerpoint directly next to the sink? ok or not? 4Mar 15, 2010 6:20 pm Take a look at viewtopic.php?f=1&t=30240&p=421411 Demolition August 2009, Construction Started September 2009, Completed December 2010 i imagine you also have another contract with an architect? and yeah, whatever other's said about special conditions and appendices 16 16010 Hi all I am looking to run a water line under my concrete footpath which is directly next to my home, was seeing if this is possible without cutting the entire section… 0 20183 Did you know that you can get rugs made from carpet? So much cheaper than buying a shop rug. So many styles to choose from, but you won't get the highly patterned… 0 6277 |
