Browse Forums General Discussion 1 Mar 07, 2010 11:13 am Does anyone know the aust standard or building code number for how close you are able to build a concrete inground pool to a house and fence. House side i think refers to angle of repose ? just need numbers so i can print out at work . Thanks Re: AUST STANDARDS 3Mar 07, 2010 7:05 pm May be here... http://www.buildingcommission.com.au/re ... _FINAL.pdf "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: AUST STANDARDS 4Mar 08, 2010 11:09 am If you contact your local council they have all that information. We picked up a couple of flyer sheets they had. We are just going through the process now (fibreglass pool). It's not so straight forward, there are some exceptions if you want to build closer to a boundary fence. They quote "in accordance with Part 10 of the Building Regulations 1989" and also the fences/wall also have to comply with AS1926.1 Good luck. Building Standards; Getting It Right! Don't think they are designed for double brick. WA has a particular way of building and unfortunately that's the way a large amount of sills are finished. 3 7036 I believe this is correct. From the picture you can see the power was put in last so the electrician knew where the water was. Really it's a common sense issue more… 4 5166 2 8657 |
