Browse Forums General Discussion 1 Mar 05, 2010 7:46 pm Hey All, The council have rejected my plans as I am trying to build my garage on a storm water pit. They said they have no issue me building on pipes just not the pit. My builder suggested moving the pit. I have now sent a revised plan back with the proposal to move the pit. Has anyone ever moved a pit? Cheers Thanks for that, the PVC pipe is still about 40cm below ground level and it sticks out of the sand with no end cap or anything on it just open pipe, is this the finished… 2 10480 Hello I am developing 2 side by side units. Wish someone can help me on the following questions 1) Which stage should be the storm water pipe installed during the new… 0 7816 If you need to be able to access these then you may need to dig them out and cut them so you can add a socket and a riser to the required height. We normally add a… 1 6846 |
