Hi, I am seeking some info on building a besser brick/block structure as an outbuilding/storage shed. I want to make it two stories, but am stumped before I begin. How do I determine how many bricks I need to build it? I have worked with the so many bricks per layer per side, but not sure if that is correct. Also, I know about using rod-ing and reo for the walls and footings, but not how to work out how deep the footings need to be to be sufficient for wall hieght. I am acknowledging that I may actually need to make the walls double brick to allow for load bearing capacity if the wieght of the structure itself.
Can anyone supplies tips, tactics or information?
R
