Browse Forums General Discussion 1 Aug 19, 2007 8:02 pm Hi all,
Can anyione point me to, or advise me of the minimum and maximum step heights for timber steps? I am planning a merbau deck (70mm) to go over our concrete porch, but want to extend it out a little, so it will need a step. I cant find anything on our council website, but I think it would be a building regulation height, not a council requirement? This is for Hoppers Crossing in Melbourne. Thanks in advance Adrian B Re: Minimum / Maximum Step Height 2Aug 19, 2007 8:39 pm Adrian,
The Building Code of Australia provies the information you need. First some terms. Rise is the height between steps and Going is the length of the flat bit. The requirements are: 1) Rise = 115 to 190 mm 2) Going = 240 to 355 mm (preferably 265 to 355 mm) 3) 2 x Run + Going = 550 to 700 mm Cheers, Casa Demolition August 2009, Construction Started September 2009, Completed December 2010 Re: Minimum / Maximum Step Height 3Aug 19, 2007 9:42 pm I have no actual knowledge about this, and the previous post seems to have answered the question, but....
Isn't it also a requirement that the steps are fairly consistent in dimensions? (ie. Each step should be about the same rise and going in each flight) I thought this was so, but I may be wrong. Ash. Re: Minimum / Maximum Step Height 5Aug 20, 2007 2:37 pm ![]() I have no actual knowledge about this, and the previous post seems to have answered the question, but.... Isn't it also a requirement that the steps are fairly consistent in dimensions? (ie. Each step should be about the same rise and going in each flight) I thought this was so, but I may be wrong. Ash. yes you are correct ![]() The distance between my DEBs varies from 4.1m at the narrowest to 8.1m at the widest. 5 5480 ![]() Thanks again for this information. If you do hear anything different, would be great to know 4 2893 My land is 260m2 (10m x 26m) located in claymore NSW. Under campbelltown council. I know in general the following setbacks would apply ground floor side setback =… 0 2798 |
