Browse Forums General Discussion Re: Cost of a false ceiling…. That can’t be right?? 2Feb 19, 2010 9:20 pm crikey, for that amount i'd at least be expecting a real one...! sorry, no idea what a false ceiling is or how much it'd cost, hope someone else can help you out "Your emotions are the slaves to your thoughts, and you are the slave to your emotions." — Elizabeth Gilbert Living in our new house. Currently scaping the land. Re: Cost of a false ceiling…. That can’t be right?? 3Feb 19, 2010 9:23 pm That seems quite ludicrous really. Well over priced however I don't know what the standard rates are. Re: Cost of a false ceiling…. That can’t be right?? 4Feb 19, 2010 10:31 pm To drop a flush ceiling on a Rondo furring channel system shouldn't cost you much more than $80 per sqm at the outside finished , depending on what drop and what anchors(under concrete) you may need, materials for the suspension system shouldn't be more than $15 per sqm, add $45 per sqm for the Gyprock and labor tops Re: Cost of a false ceiling…. That can’t be right?? 6Feb 21, 2010 11:23 am Hi Nic_s, Rough cost prices of the Rondo system ie top rails @1200 centres, furring channels@600 centres should be about $2.50 plm for these items then you have rods, clips, anchors etc--maybe another $300 tops. The Gyprock alone is about $5.50psqm, if you allow around $12psqm cost (cornice,glue, screws plaster etc), that should cover it. Then the labour on top (easy bottom floor access) lets say $5k tops (not too sure about Sydney prices??). I would recommend going to a local ceiling company outlet with your plans, they will give you the quantities and they probably will have their own contractors or names of subbies they recommend, you should be able to get a total price from them, most of these outlets CSR, Boral, etc.,are usually pretty competitive. Re: Cost of a false ceiling…. That can’t be right?? 8Mar 25, 2010 9:58 am I am also looking at a false ceiling for a renovation and want to achieve acoustic isolation equal to or better than Rw 50. I believe I can do this by using resilient hangers and one layer of plaster or by adding extra layers of plasterboard. Does anybody have an idea of the cost of labour for an additional layer of plasterboard on the ceiling? I'm putting a new floor in my kitchen, slate flagging on a standard concrete slab. I have allowed for a bed thickness of up to 20mm to accommodate the different… 0 17543 They using concrete or timber sleepers? Timber or steel uprights? Any drainage behind sleeper? 3 5891 Thanks for that, the PVC pipe is still about 40cm below ground level and it sticks out of the sand with no end cap or anything on it just open pipe, is this the finished… 2 10473 |
