Browse Forums General Discussion 1 Feb 15, 2010 12:36 pm I'm arranging a pre-plaster inspection. Am just a little confused about the order in which things are done. Our house has just been wrapped, and rough-ins almost complete. I'm told by our administrator that plaster is going on in next few days leaving me precious little time to organize an inspection! I was expecting plaster not to go on until bricking was done. Can anyone advise if this sounds right? also inspector recommendations for SSE of Melbourne? Re: bricks, then plaster? or wrap, then plaster? 2Feb 15, 2010 12:55 pm Bricks are supposed to go up first then plaster in installed once house is sealed and the walls can be straightened. If the house is not air tight the wall are unable to be straightened as they can still move with changes in whether. In saying that this is not always the process that builders follow. Re: bricks, then plaster? or wrap, then plaster? 3Feb 15, 2010 9:05 pm Thanks for your reply. I've managed to book an independent building inspector. He said this is called 'reverse building'. Like you said, not the norm, but sometimes done. Hey guys building a new place through a volume builder and just wondering if i should complain to the site supervisor as we just had plasterboard installed. Looks like… 0 11269 I am in the same situation, would you be able to give some insights in to this? I am in SA 8 17044 Vapour permeable wraps are recommended for any climate and main think it is allow walls to breath (i.e. remove water vapour) while at the same time, providing protection… 4 9775 |
