Browse Forums General Discussion 1 Feb 14, 2010 2:38 pm I have an old shed on a small rural property. It is 5m wide by 12m long. The 5M long rafters are supported, at each end, on 200/250mm dia "tree trunks". In the middle of each rafter there is a 75 x 75 mm support post. The roof is flat and covered with cliplock metal sheeets. At one end of the shed, I would like to remove the support post of the first rafter, so that I have a clear floor space to work in. This will mean replacing the existing rafter with a stronger(wider/thicker) one My problem is, I don't know what size timber I should use. I have looked at heaps of tables etc for rafter sizes, but couldn't find one that covers "ye olde flat iron roof". Any and all suggestions will be much appreciated. Thanks Dear Members I have to decide the Facade column size. My custom builder standard is 350mm with rendering, but i asked for 470mm plus stone or tiles and yet to get… 0 7497 All sorted guys. Just needed to buy a blade with the correct bush. Dunno how to delete this post, can't find any help file. Cheers. 1 3664 Current door width is approx 2700, looking to have double doors fitted 820-820. What size does the frame need to be before door jamb? Thanks 0 3548 |
