Browse Forums General Discussion 1 Feb 12, 2010 9:49 pm hi, we experienced several times of heavy rain. I found when the rain, together with very strong wind, the garage floor-slab ( neary the periphery of the brick wall side) will get a bit wet. This happened once or twice so far. Our garage has 2 internal walls plastered, the wall near the lot boundary is brick only. The rear access garage door ( the 820mm wide one) already got a strip of sealer. Is that normal? Thanks. Re: Do u garage ( interal) get wet when heavy rain? 2Feb 13, 2010 7:36 am In the massive storm we had last year I had rain come in under the rear pedestrian door as there is a gap and the rain came from the north in the wind, but that's the only time really. If your door is facing west or south and there is a gap underneath it wouldn't surprise me. If you go to bunnings you might be able to get one of those meal things for the base of the door that help stop the air coming in/out, it might help stop the rain too. 'A bottle of wine contains more philosophy than all the books in the world.' Louis Pasteur Vegie garden: viewtopic.php?f=19&t=27637&start=0 My Backyard Adventure Re: Do u garage ( interal) get wet when heavy rain? 3Feb 13, 2010 9:12 am Do you have weep holes at the bottom of that brick wall that seems to be "letting the rain in"? If not, the water is possibly just sitting there and is looking for the least resistant route to escape ... Does anyone know why an external garage brick wall "doesn't need" weep holes?? Especially if that wall is going to be plastered internally?? Doesn't make any sense to me ... My signature is distracting people from my wise posts ... Re: Do u garage ( interal) get wet when heavy rain? 4Feb 13, 2010 11:02 am Nup lex, no reason why not... Not too hard to put some in though Where you are coming from is where you are going to... Re: Do u garage ( interal) get wet when heavy rain? 6Feb 13, 2010 11:41 am onc_artisan Nup lex, no reason why not... Not too hard to put some in though Weep holes are easy, but what about the associated flashing? Demolition August 2009, Construction Started September 2009, Completed December 2010 Re: Do u garage ( interal) get wet when heavy rain? 7Feb 13, 2010 11:46 am There is flashing, but no holes (on that single skin wall, and the wall will be plastered internally). I was already tempted long ago to "construct" them, but wasn't sure if that would be wise ... many garages don't have them (but still doesn't make sense why not). My signature is distracting people from my wise posts ... Re: Do u garage ( interal) get wet when heavy rain? 8Feb 13, 2010 11:52 am If it is a single skin then moisture ingress protection (Siloxane penetrant sealer) to stop ingress from external. Weep holes in a single skin have no relevance as the weep hole is for cavity moisture relief... though I could be wrong casa - I was referring to a relief point more than an engineered weep hole. A caulking chisel... Google says all other kinds but the one I am talking about has an angled face with a pointy end. Like a cold chisel but not a flat head it has an angle of about 60 deg. This could be a better description... Like a narrow chisel about 4mm wide but with a longer face If my camera was about I could take a photo Where you are coming from is where you are going to... Re: Do u garage ( interal) get wet when heavy rain? 10Feb 14, 2010 9:05 am Part 3.3.4.3 (Cavity Ventilation and Drainage) of the BCA requires that "Open perpendicular joints (weepholes) must be created in the course immediately above any damp-proof course or flashing". It doesn't look like there are any exceptions to garages - ?! My signature is distracting people from my wise posts ... Re: Do u garage ( interal) get wet when heavy rain? 11Feb 14, 2010 1:11 pm Oh onc, I even had to look up the cold chisel So, something like that, but with a bent part ... (btw, is your camera working ) My signature is distracting people from my wise posts ... Re: Do u garage ( interal) get wet when heavy rain? 12Feb 14, 2010 1:13 pm NO currently on a jobsite I think Thats why no photos of anything else I might see if I can draw one on sketchup... BIaM something like this Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Where you are coming from is where you are going to... Re: Do u garage ( interal) get wet when heavy rain? 13Feb 14, 2010 1:54 pm I thought that was a good effort Where you are coming from is where you are going to... Re: Do u garage ( interal) get wet when heavy rain? 14Feb 14, 2010 2:14 pm Aaaaa, that's what you meant!! I was picturing bends in the material Thank you! makes sense ... And hope your camera survives the site My signature is distracting people from my wise posts ... Re: Do u garage ( interal) get wet when heavy rain? 15Feb 14, 2010 2:20 pm Where you are coming from is where you are going to... Re: Do u garage ( interal) get wet when heavy rain? 16Feb 14, 2010 2:35 pm Nott hi, we experienced several times of heavy rain. I found when the rain, together with very strong wind, the garage floor-slab ( neary the periphery of the brick wall side) will get a bit wet. This happened once or twice so far. Our garage has 2 internal walls plastered, the wall near the lot boundary is brick only. The rear access garage door ( the 820mm wide one) already got a strip of sealer. Is that normal? Thanks. I think the problem IS ingress. Weep holes won't in my opinion help. Penetrant sealer only... but don't use a membrane type sealer they breakdown via abrasion and UV damage... Though most likely the issues are on the southern side so will get minimal sunlight... still don't recommend them as they are subject to movement and this will 'break' the seal. Where you are coming from is where you are going to... Re: Do u garage ( interal) get wet when heavy rain? 17Feb 15, 2010 4:42 pm onc_artisan ... Weep holes won't in my opinion help. Penetrant sealer only... but don't use a membrane type sealer they breakdown via abrasion and UV damage... Though most likely the issues are on the southern side so will get minimal sunlight... still don't recommend them as they are subject to movement and this will 'break' the seal. So onc, what's Penetrant sealer (I mean brand name if possible ) and where do you apply it (to internal bare brick wall or external, or elsewhere)???? When you say "still don't recommend them as they are subject to movement and this will 'break' the seal", do you mean the weep holes or the "membrane type sealer"? My signature is distracting people from my wise posts ... Re: Do u garage ( interal) get wet when heavy rain? 18Feb 15, 2010 8:09 pm Lex onc_artisan ... Weep holes won't in my opinion help. Penetrant sealer only... but don't use a membrane type sealer they breakdown via abrasion and UV damage... Though most likely the issues are on the southern side so will get minimal sunlight... still don't recommend them as they are subject to movement and this will 'break' the seal. So onc, what's Penetrant sealer (I mean brand name if possible ) and where do you apply it (to internal bare brick wall or external, or elsewhere)???? When you say "still don't recommend them as they are subject to movement and this will 'break' the seal", do you mean the weep holes or the "membrane type sealer"? Penetrant = Seeps in I don't get paid to advertize. Nor 'give away' years of learning about products I buy. External treatment. Where you are coming from is where you are going to... Firstly, if your house is still under builder's warranty (10 years in Victoria) you should have no need to crawl into roof space but let the builder handle it, unless you… 3 5633 What size are the windows, double or single glazed, can I have a pic of the full windows inside & out? If you can see packers please take a pic. 1 12383 All sorted guys. Just needed to buy a blade with the correct bush. Dunno how to delete this post, can't find any help file. Cheers. 1 3658 |
