Browse Forums General Discussion Re: Do u garage ( interal) get wet when heavy rain? 2Feb 13, 2010 7:36 am 'A bottle of wine contains more philosophy than all the books in the world.' Louis Pasteur Vegie garden: viewtopic.php?f=19&t=27637&start=0 My Backyard Adventure Re: Do u garage ( interal) get wet when heavy rain? 4Feb 13, 2010 11:02 am Where you are coming from is where you are going to... Re: Do u garage ( interal) get wet when heavy rain? 8Feb 13, 2010 11:52 am Where you are coming from is where you are going to... Re: Do u garage ( interal) get wet when heavy rain? 12Feb 14, 2010 1:13 pm Where you are coming from is where you are going to... Re: Do u garage ( interal) get wet when heavy rain? 13Feb 14, 2010 1:54 pm Where you are coming from is where you are going to... Re: Do u garage ( interal) get wet when heavy rain? 15Feb 14, 2010 2:20 pm Where you are coming from is where you are going to... Re: Do u garage ( interal) get wet when heavy rain? 16Feb 14, 2010 2:35 pm Where you are coming from is where you are going to... Re: Do u garage ( interal) get wet when heavy rain? 18Feb 15, 2010 8:09 pm Lex onc_artisan ... Weep holes won't in my opinion help. Penetrant sealer only... but don't use a membrane type sealer they breakdown via abrasion and UV damage... Though most likely the issues are on the southern side so will get minimal sunlight... still don't recommend them as they are subject to movement and this will 'break' the seal. So onc, what's Penetrant sealer (I mean brand name if possible ) and where do you apply it (to internal bare brick wall or external, or elsewhere)???? When you say "still don't recommend them as they are subject to movement and this will 'break' the seal", do you mean the weep holes or the "membrane type sealer"? Penetrant = Seeps in I don't get paid to advertize. Nor 'give away' years of learning about products I buy. External treatment. Where you are coming from is where you are going to... Firstly, if your house is still under builder's warranty (10 years in Victoria) you should have no need to crawl into roof space but let the builder handle it, unless you… 3 5633 What size are the windows, double or single glazed, can I have a pic of the full windows inside & out? If you can see packers please take a pic. 1 12383 All sorted guys. Just needed to buy a blade with the correct bush. Dunno how to delete this post, can't find any help file. Cheers. 1 3657 |
