Browse Forums General Discussion 1 Feb 11, 2010 10:52 am We paid extra for "off-white' mortar which is described in the colours booklet as white sand + white cement. As opposed to their natural mortar described as yellow sand + grey cement.
We're wondering if this delivery is white or yellow? Can anyone compare? Interesting admin have told me they use the same sand for both mortars, just different coloured cement! http://i562.photobucket.com/albums/ss69/sierra_099/th_IMG_6693.jpg Re: white sand? 3Feb 11, 2010 11:00 am Take a bit and dry some bet you find it is quite white when dry. That and white(off white)cement should get you close... This is considered white sand from our property Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Where you are coming from is where you are going to... Re: white sand? 5Feb 11, 2010 11:08 am Dry is NO moisture... if any of the grains stick together then it is not dry. Is it like powder? Where you are coming from is where you are going to... 2 8890 I'm putting a new floor in my kitchen, slate flagging on a standard concrete slab. I have allowed for a bed thickness of up to 20mm to accommodate the different… 0 17545 2 4356 |
