Browse Forums General Discussion Re: Steel Frame overhanging.....???? PLEASE HELP 2Jan 29, 2010 11:06 pm I'm no expert, far from it, but if there's at least two-thirds bearing on solid concrete, I would have thought that it would be OK. Demolition August 2009, Construction Started September 2009, Completed December 2010 Re: Steel Frame overhanging.....???? PLEASE HELP 3Jan 29, 2010 11:49 pm Hmmmm, I wonder what makes you say that, Casa? Are the rules different for steel and timber? I know the tolerance for timber frame (1 cm), but not sure if it applies to steel as well. I would have thought that steel would need to be supported even better than timber Bromaco, here is the doco that people use for this kind of thing: http://www.buildingcommission.com.au/resources/documents/S+T_GUIDE_07.pdf Do you have any pics for us?? My signature is distracting people from my wise posts ... Re: Steel Frame overhanging.....???? PLEASE HELP 4Jan 30, 2010 7:40 am have a fair bit of overhang as well would love to see how significant yours is so I can compare it to ours ... Re: Steel Frame overhanging.....???? PLEASE HELP 5Jan 30, 2010 9:43 am Lex Hmmmm, I wonder what makes you say that, Casa? Are the rules different for steel and timber? I know the tolerance for timber frame (1 cm), but not sure if it applies to steel as well. I would have thought that steel would need to be supported even better than timber Bromaco, here is the doco that people use for this kind of thing: http://www.buildingcommission.com.au/resources/documents/S+T_GUIDE_07.pdf Do you have any pics for us?? Lex, Thanks for that. So only 10 mm is allowed for 90 mm walls and 15 mm for 110 mm brickwork. Another thing to note is that fixing into the slab must be a minimum of 50 to 70 mm from the edge. This may end up being a harder thing to satisfy if there is a lot of overhang. Bromaco, How much overhang do you have? Cheers, Casa Demolition August 2009, Construction Started September 2009, Completed December 2010 Re: Steel Frame overhanging.....???? PLEASE HELP 7Jan 30, 2010 1:36 pm That's more than 50%! What does the builder say? Have you thought of engaging a qualified independent inspector? How far is your build? Casa, forgot to say, I asked because I heard something similar to what you said - that about 1/3 is still OK to overhang (this is for timber frames) - unofficially. Because this is unofficial and unconfirmed (and an isolated opinion of an individual), I thought better to stay within the published tolerances, better safe than sorry. So it's interesting that it seems that you heard similarly. My signature is distracting people from my wise posts ... Re: Steel Frame overhanging.....???? PLEASE HELP 8Jan 30, 2010 6:41 pm Lex That's more than 50%! What does the builder say? Have you thought of engaging a qualified independent inspector? How far is your build? Casa, forgot to say, I asked because I heard something similar to what you said - that about 1/3 is still OK to overhang (this is for timber frames) - unofficially. Because this is unofficial and unconfirmed (and an isolated opinion of an individual), I thought better to stay within the published tolerances, better safe than sorry. So it's interesting that it seems that you heard similarly. I came up with the one-third figure using logic. The way I look at it, as long as two-thirds of your frame is bearing on good concrete, it would be OK. Now over 50% ... that's disgusting! Demolition August 2009, Construction Started September 2009, Completed December 2010 Re: Steel Frame overhanging.....???? PLEASE HELP 9Feb 02, 2010 7:32 pm Our steel frame guy has now fixed all the overhanging bits. YAY! Re: Steel Frame overhanging.....???? PLEASE HELP 11Feb 02, 2010 8:55 pm Casa2 gettingThere Our steel frame guy has now fixed all the overhanging bits. YAY! How? From what I can see he just cut off the extras and put the "sides" together so that it fits perfectly (as in he cut the length not the thickness of the pannels - if that makes sense) Re: Steel Frame overhanging.....???? PLEASE HELP 12Feb 02, 2010 9:54 pm gettingThere Casa2 gettingThere Our steel frame guy has now fixed all the overhanging bits. YAY! How? From what I can see he just cut off the extras and put the "sides" together so that it fits perfectly (as in he cut the length not the thickness of the pannels - if that makes sense) So, he moved the offending wall over by reducing the two adjacent walls? Demolition August 2009, Construction Started September 2009, Completed December 2010 Re: Steel Frame overhanging.....???? PLEASE HELP 13Feb 02, 2010 10:38 pm Casa2 gettingThere Casa2 How? From what I can see he just cut off the extras and put the "sides" together so that it fits perfectly (as in he cut the length not the thickness of the pannels - if that makes sense) So, he moved the offending wall over by reducing the two adjacent walls? Yes, that is exactly what I meant Re: Steel Frame overhanging.....???? PLEASE HELP 14Feb 03, 2010 7:29 am I'm glad the builder fixed it up properly rather than patched it up. Sounds like you have a good builder. Demolition August 2009, Construction Started September 2009, Completed December 2010 Re: Steel Frame overhanging.....???? PLEASE HELP 15Feb 03, 2010 9:23 am i wish our builder was as good as yours.........they keep telling us that it is normal...........ummmmm hello i dont think so!!! By the way i got it wrong earlier i said it overhangs 55mm on a 90mm frame WRONG it overhangs 55mm on a 70mm frame, YES 70mm! Now we have fond out that our $8k roller doors dont fit cause the builders have stuffed up the door sizes......NOT A VERY HAPPY CAMPER HERE!!!! Re: Steel Frame overhanging.....???? PLEASE HELP 16Feb 03, 2010 9:42 am Bromaco i wish our builder was as good as yours.........they keep telling us that it is normal...........ummmmm hello i dont think so!!! By the way i got it wrong earlier i said it overhangs 55mm on a 90mm frame WRONG it overhangs 55mm on a 70mm frame, YES 70mm! Now we have fond out that our $8k roller doors dont fit cause the builders have stuffed up the door sizes......NOT A VERY HAPPY CAMPER HERE!!!! We are owner builders and choose a good steel frame installer ourselves, which is good. Re: wrong roller door sizes Is the gap wrong? Can it be modified to fit the door? Our steel frame company missed out on a few doors, our steel frame guy is just going to cut out the wholes etc. Good luck! Hi I am wanting some opinions about the build of a steel shed I am going to get one about 4.5 x 2.5 m steel shed and the height will be about 2.3-2.4m high The one I am… 0 14442 This is 100% true. You can not hang anything on steel frames. very frustrating 8 8004 Hi, I have a steel frame house which was built 2 years ago. When you are down stairs you can hear clunking noises when someone is walking around. We were told if you… 0 4450 |
