Browse Forums General Discussion Re: Panel Lift Garage Doors 2Jan 27, 2010 1:50 pm ihjan I want to have a panel lift door installed in Adelaide and have found only 3 different products available. Is there a wider range available? It all depends on what company you have choosed to get installed through. Re: Panel Lift Garage Doors 6Jan 28, 2010 7:33 am If you are after brands B and D are one of the better ones. If you have a slightly non standard opening they make the pattern to match the openeing. With some companies if you have a slighlty larger or smaller opening than the standard they use the same template pattern and the pattern may be to far or to close to the edge. Of course this is only relivent when you order the square boxes pattern (not sure of the proper name). ALso the cheaper doors do not have a wood grain finish which make the door panel look a little bit glossy and then you see the ripples in the pane. Also consider going fo the merlin belt drive motor. It's a classic case of aesthetics subjugating function where style takes precedence over practicality. 3 3945 It sounds like you have a crack in your garage where the wall meets the ceiling, along the shadow line on the… 0 17202 |
