Browse Forums General Discussion 1 Jan 26, 2010 7:22 am We're about halfway thru building our shed which in the short term will be our home, and in the long term will be a workshop. We're looking at using LED lighting instead of fluoros, as they run cooler & last longer, and are investigating whether to wire for 240v or 12v. I know that this is a pretty untried area, but has anyone gone for LED ceiling lights so far and if so, how are they working out ? Re: LED Lighting 2Jan 27, 2010 6:22 pm g'day as an electrican, i have found people wish they didnt go led lighting. yes they do last longer but the light given is a weird BRIGHT WHITE doctors surgery light that plays on peoples eyes.. i would stick to convential lighting.. BUT having said that everyone is different.. go to a lighting shop and compare the different types of lights they have to offer.. tell them your situation. i hope it works out chris Electrical - Automation - Smart wiring - New homes - Commercial - Data cabling] 1300 050 315 www.cenemelectrical.com.au www.facebook.com/cenemelectrical Building Standards; Getting It Right! 1. optional, you can but normally just use the earth from the main switch board 2. should be enough but the distance determines voltage drop - sparky should work it… 1 28805 I have a really long hallway which is 1100mm W x 11500mm L I would appreciate if anyone can give suggestions to light it up with Linear LED lights that goes from wall to… 0 8811 |
