Browse Forums General Discussion 1 Jan 13, 2010 3:36 pm I would appreciate any advice you could give, on running cables through a 2 bedroom apartment with rendered brick walls. Need to have the following cables in different locations; -TV -Fox -Phone -Power Been tossing around several ideas such as putting cables behind larger skirting boards or up on the ceiling behind bulkheads. Now thinking about putting a floating wooden floor in the apartment over the concrete slab. I believe this could give an opportunity to run the afore mentioned cables around the apartment and then chase the cables up the wall where I need outlets. Biggest question; is there a legal way to run power under or around the edge (where floor meets wall) of a floating wooden floor? What conditions, clearances etc. are required? This will help us decide if this is the best idea for us. Or if anyone has had a similar cabling problem in a house or apartment with rendered brick walls would like to hear how you solved it. Thanks P.S we will not be doing this work ourseleves, will be getting a professional in to do, i would just like to know what options we have. Hi all I am looking to run a water line under my concrete footpath which is directly next to my home, was seeing if this is possible without cutting the entire section… 0 20191 Thanks, that's the motivation I needed to give it a try sooner rather than one day! 4 3019 To put anything over slate you will need to put self level compound over the entire area as slate various in thickness and is very un even. To install most types of… 1 419 |
