Browse Forums General Discussion 1 Jul 27, 2007 11:30 pm Hi,
I seem to have a great many problems trying to cut a straight line with a jigsaw. It always wants to veer off line, the blade seems to bow. I find myself lifting the jigsaw's base off the timber to force it to cut along the pencil line but this doesn't give a satisfactory cut. It usually also ends up cutting on a downward angle that isn't at a right angle. I don't know if I need a higher end machine, because this has happended with 2 different jigsaws. Also I'm lefthanded and maybe jigsaws are designed to be cut by right hand (like most things in this world!!) Any tips welcome, cheers Re: jigsaw problems 2Jul 28, 2007 7:36 am Your answers lie here..
http://www.extremehowto.com/xh/article.asp?article_id=60232 But in short: Straight-line Cuts. Use a firmly clamped, straight guide fence to make long, straight regular or bevel cuts. For further accuracy on straight cuts, a wider jigsaw blade is less likely to curve outward during cutting. Also, use a slower blade speed. Slower speeds generally allow more accurate cuts. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ I am not a brick expert, but rendering would be 1 option, it would be costly to do the entire house though.... 2 8522 Hi all, has anyone been ask to do the weeds in their property while in the middle of build? We are under the impression that they are in control of the site while they… 0 5190 Have had a few issues with out recently done bathroom floor. Probably around 18 months old First there has been been a crack running through a grout line which I put… 0 4514 |
