Hi All
Can anyone advise what a crossover is in regards to an estate or in general
Thanks
Browse Forums General Discussion Re: Covenants - What is a crossover 2Dec 27, 2009 8:35 am The bit that goes from the road edge to your land ... crossing over the council/shire/estate. land to get to yours Where you are coming from is where you are going to... Re: Covenants - What is a crossover 3Dec 27, 2009 8:48 am onc_artisan The bit that goes from the road edge to your land ... crossing over the council/shire/estate. land to get to yours Thanks for that, I wasnt sure if it was this or the adjoining block. Cheers Re: Covenants - What is a crossover 4Dec 27, 2009 9:59 am be careful if you wish to change a cross over as well. Many infrastructure bits are aligned to the existing orientation. if you swap over you risk shelling out for moving pipes and stuff. Re: Covenants - What is a crossover 5Dec 27, 2009 10:08 am Eve Dweller be careful if you wish to change a cross over as well. Many infrastructure bits are aligned to the existing orientation. if you swap over you risk shelling out for moving pipes and stuff. Thanks - Good point, another thing you dont think of unless you ask someone who doesnt make some money out it. Re: Covenants - What is a crossover 6Dec 27, 2009 10:13 am Sometimes the people that earn their money from something can also have the knowledge to be able to help. ...without passing a cost on. Where you are coming from is where you are going to... Re: Covenants - What is a crossover 7Dec 27, 2009 10:21 am onc_artisan Sometimes the people that earn their money from something can also have the knowledge to be able to help. ...without passing a cost on. Thats the beauty of this website, glad I found it and people are eager to share that may be in the industry. Re: Covenants - What is a crossover 8Dec 27, 2009 10:34 am I have to say that you would be better to have only one thread going Also I be hard pressed to listen to someone not in the industry tell me how it works Where you are coming from is where you are going to... Hi Everyone I learned something this week that I thought would be worth sharing. In NSW a lot of developers of subdivisions put covenants on the land which normally… 0 6580 |
