Browse Forums General Discussion 1 Dec 24, 2009 8:25 am Has anyone modified their roof space and turned it into an attic, if so, how did you go about doing it and roughly what costs were involved? Do you have any pics? Current status: Busy making the house our home Built PD Francis 29 on our 576m2 block at Reflections in Tarneit Reflections Estate Thread Our Build Thread Re: Converting roof space into attic 2Dec 24, 2009 9:15 am I've heard that it can void the warranty on your roof trusses if they weren't originally designed for it 'A bottle of wine contains more philosophy than all the books in the world.' Louis Pasteur Vegie garden: viewtopic.php?f=19&t=27637&start=0 My Backyard Adventure Re: Converting roof space into attic 3Dec 24, 2009 9:35 am Prefabricated roof trusses are designed for roof loads...one is the static weight of the roof and the other is wind loads. With the former the loading can be quite heavy for roof tiles or quite light for colorbond. With the latter the worst load is generally an uplift load where the wind is trying to peel your roof off. What does this mean? None of these loads are consistent with the purposes of an attic - dead loads from (things in the attic) and live loads (human occupancy) all acting downwards on the bottom horizontal member (chord) of the truss. So the truss would need to be redesigned (yes...that means an engineer) and strengthened. Strengthening could mean propping from below, increasing the capacity of the bottom chord, additional vertical members between the top and bottom chord, redesign of truss end connections, to worst case scenario a purpose built attic truss. So IMO a general cost is impossible to provide without a professional assessing the capacity of the existing truss and how the roof system "works"....every job will be different. And Lisanne is correct if your house is younger than the structural warranty period that came with the house modifications like this will void the warranty...which is why you need to be careful about installing an attic ladder...if that's your intention than the builder needs to design the trusses accordingly. Cheers, Mike mmm....donuts Homer Simpson 1956- Links: Site Costs Ready Reckoner | H1 Addiction Medical Advice | Château TDL: The Backyard Re: Converting roof space into attic 4Jan 05, 2010 7:29 pm to_do_list is correct a prefabricated truss roof is designed to span the ceiling and as such the bottom chords of each truss is under tension (load) if this load is changed to compression (load) then a roof can fail, this can happen by simply jambing a pice of wood under a truss and internal wall so it is sitting the wall, this can literally cause the truss to snap in two. However, if you have an old hose that has a Pitched roof then you are in luck and the load on these roofs are transferred through bearers on onto internal load bearing walls. Chris Re: Converting roof space into attic 5Jan 05, 2010 7:42 pm Correct Striking - but I knew that Sega is building a new house and therefore it would be prefab truss. mmm....donuts Homer Simpson 1956- Links: Site Costs Ready Reckoner | H1 Addiction Medical Advice | Château TDL: The Backyard Re: Converting roof space into attic 6Jan 06, 2010 11:56 am Hi Wizzard, My regular sparky does work for Attic Ladders in Oakleigh. The specialise in roof space conversions. Might be worth a call. Cheers PP start from at least $20,000 just for fixtures and finishes and then add on for moving plumbing and extra for a concrete floored house last new bathroom we installed in a… 1 19585 2 9445 If I hire a contractor to convert a window to a sliding door will I need to show them Council approval paperwork? That is, if I want to take a risk of carrying out the… 0 13009 |
