Browse Forums General Discussion 1 Dec 19, 2009 4:58 pm What is the standard door opening height and width when framed in 2x4s with out trim ect..? I know the size of the door u buy would govern this but id imagine most internall doors are al the same.? Re: standard door heightxwidth when framed.? 2Dec 19, 2009 5:18 pm 2040 x 870 2040 x 760 Where you are coming from is where you are going to... Re: standard door heightxwidth when framed.? 3Dec 19, 2009 5:27 pm I have this in my notes from another site. For a 820 wide door. Total trim opening width should be: Door 820 Jamb 19mm each side allowance for plumbing jambs 10 clearance between door and jamb 3mm each side total trim width 874 Total trim opening height should be: Door 2040 head 19 allowance for levelling head jamb 3 allowance for floor covering 20 (vinyl is only 12) clearance between head jamb and door 3 Total trim height 2085 What we have done in a few theatres ( including my own) is run 2 layers of 13mm gyprock, but sounds insulation especially for the bass is really tricky as a lot of that… 4 2569 Black on light wood does look good. Not sure if it will be as long lasting as a steel finish? 6 6352 I’m in a similar position except I’m after sliding 3 stacking doors. I am on a second-story apartment of which the balcony would not adequately fit any bi-fold or… 5 16150 |
