Browse Forums General Discussion 1 Jul 21, 2007 10:57 am I'm thinking of buying an art deco house which currently has a tile hip roof with internal gutters. The roof urgently needs replacing...
But instead of replacing the roof, I'm think of adding a small extra room on top and making the roof flat (as per standard art deco design). I'm pretty sure the house structure can take it as I've had an engineer take a quick look. What I am wondering though is what happens to the electricals, exhaust fan outlets and such that currently run in the roof space ? And how do you handle insulation with a flat roof ? I think that the electricals in the house should also be replaced very soon. Should that happen simultaneous with the extension ? Or after ? Or maybe before ? And where do I start ? Get the engineer back to check the structure, then a builder ? Or a draughtsman / architect ? So many questions.... Thanks Re: Pitched roof to flat 2Jul 22, 2007 10:46 pm You would definately want to do any electrical at the same time. There are slimline vented exhaust fans for small clearances that duct out through the eaves.
You would really notice the differece in summer especially with no roof space. It is cellulose fibre blow in insulation. Basically shredded news paper that is blown into the roof space. It was very popular in the late 90's. It's messy stuff and has… 1 16421 ![]() Hi all! I am building a patio over my deck, and I am using the roof extenda brackets to create the fly-over roof another the eaves. It will be approx 3m wide by 4.5m long… 0 9352 Hi all, My home has a steel flat roof and due to having three air conditioners, a satellite dish, a skylight, and an antenna up there, the labour cost to have the sheets… 0 1212 |
