Browse Forums General Discussion Re: Phone line Installed, What to do next? 3Dec 16, 2009 7:18 pm 'A bottle of wine contains more philosophy than all the books in the world.' Louis Pasteur Vegie garden: viewtopic.php?f=19&t=27637&start=0 My Backyard Adventure Re: Phone line Installed, What to do next? 5Dec 16, 2009 7:28 pm 'A bottle of wine contains more philosophy than all the books in the world.' Louis Pasteur Vegie garden: viewtopic.php?f=19&t=27637&start=0 My Backyard Adventure Re: Phone line Installed, What to do next? 7Dec 17, 2009 9:03 am 'A bottle of wine contains more philosophy than all the books in the world.' Louis Pasteur Vegie garden: viewtopic.php?f=19&t=27637&start=0 My Backyard Adventure Re: Phone line Installed, What to do next? 8Jan 19, 2010 5:13 pm Lara and Joshua http://pdheywood25.blogspot.com/ viewtopic.php?f=31&t=31186 16.03.10 Scrape 29.03.10 Slab 08.04.10 Frame 11.05.10 Lock Up 03.06.10 Fixing 24.08.10 Handover Re: Phone line Installed, What to do next? 9Jan 19, 2010 5:20 pm Kodiak Data Cabling onFaceBook Consult*, Design and Installation Data, TV, Home Theatre/ AV Cabling, Multi Room Audio, IP CCTV and Door Intercoms Ask for a Quote. *DIY DATA Cabling Is Ilegal Re: Phone line Installed, What to do next? 10Jan 19, 2010 6:24 pm Electrical - Automation - Smart wiring - New homes - Commercial - Data cabling] 1300 050 315 www.cenemelectrical.com.au www.facebook.com/cenemelectrical Re: Phone line Installed, What to do next? 12Jan 27, 2010 6:52 pm Electrical - Automation - Smart wiring - New homes - Commercial - Data cabling] 1300 050 315 www.cenemelectrical.com.au www.facebook.com/cenemelectrical Re: Phone line Installed, What to do next? 13Jan 29, 2010 3:20 pm andy we must install a smart wiring package(part of the guidelines).2 phone lines,4 tv pts ,1 data pt .to get free to air we install our own tv antenna sounds rediculous that you have to have all that if you aren't going to use it. I certainly wasn't going to run thousands of dollars worth of cables when we are starting to go wireless. Anyway. I had to pay $299 to get the lead in cable installed(I had to dig my own trench) and $299 for telstra to connect. Does this sound right? Re: Phone line Installed, What to do next? 14Jan 29, 2010 3:55 pm PieMan andy we must install a smart wiring package(part of the guidelines).2 phone lines,4 tv pts ,1 data pt .to get free to air we install our own tv antenna sounds rediculous that you have to have all that if you aren't going to use it. I certainly wasn't going to run thousands of dollars worth of cables when we are starting to go wireless. Anyway. I had to pay $299 to get the lead in cable installed(I had to dig my own trench) and $299 for telstra to connect. Does this sound right? $299 is the standard install fee... for a new home covers conduit, NTD, cable and techs time. some builders geta the sparkeis to run the lead in conduit most of the time..which is all levels of awesome afaic... Kodiak Data Cabling onFaceBook Consult*, Design and Installation Data, TV, Home Theatre/ AV Cabling, Multi Room Audio, IP CCTV and Door Intercoms Ask for a Quote. *DIY DATA Cabling Is Ilegal Hi all I am looking to run a water line under my concrete footpath which is directly next to my home, was seeing if this is possible without cutting the entire section… 0 20189 The unit normally clips into a metal plate screwed to the wall, either plate is not flush, or unit not hooked in and could be hanging from the pipes partly, either might… 2 15798 4 10823 |
