Browse Forums General Discussion 1 Dec 16, 2009 7:13 am Good Morning, All I just got a house built and got a quotation to seal grout. The only reason for this is to protect grout as I do not like grout to get discolored after a while. I asked tradesman to use clear seal so that grout color should not change. Has anyone got any experience sealing grout? (a) Is it worth doing sealing? (b) How about appearance after sealing grout? Is it too shiny? Any comment would be appreciated. Re: Seal Grout 2Dec 16, 2009 3:13 pm viewtopic.php?f=21&t=26135&hilit=sealing+grout viewtopic.php?f=31&t=23381&p=309067&hilit=sealing+grout#p309067 Hi NcgQ, I have given you a few links to some threads re this above. There are quite a few. If you g to the search in the the box top left of the page and type in GROUT SEALING you will see quite few threads regarding this. Hope that helps.. www.themaxbuild.blogspot.com forum.homeone.com.au/viewtopic.php?f=31&t=20717&start=300 www.leahspaperpassion.blogspot.com I need to replace the worn mohair seal on my sliding window, but I can't get access to the end to slide the old one out & push the new one in. I could probably rip the old… 0 5193 4 14294 Thanks splashers, that makes sense. The waterproofing guy used this Davco product, I will raise the issue with builder and hopefully get resolved with him - if not… 2 12892 |
