Browse Forums General Discussion Re: Help Needed Putting Aerial Cable Into Wall 2Dec 15, 2009 2:36 pm Our Build https://forum.homeone.com.au/viewtopic.php?f=31&t=36661&start=40 Land Settlement - 19/07/09 Building Deposit Paid - 14/02/10 Site Scrape - 25/08/10 Slab - 01/09/10 Frame - 15/09/10 Roof - 21/09/10 Pre Wire/Plumbing - 23/04/09 Bi-Folds - 24/09/10 Bricks - 13/10/10 Plastering - 13/10/10 Cornice, skirting, shelving - 14/10/10 Re: Help Needed Putting Aerial Cable Into Wall 7Dec 18, 2009 12:45 am If you have access to the wall cavity from above and it's an external wall, then tape the cable to a length of yellow-tongue flooring "tongue" or PVC pipe (like electrical conduit) and guide it down the wall. Cut a new opening to suit your wall plate, and use a coathanger bent to a hook to locate the cable if it's not directly in front of you. May sure you turn off the power before fishing around with the coat hanger, as not all power points are completely sealed. If it's an internal wall you are probably getting hung up on the noggin. Drilling a new hole with an extension bit is the best way, but you may need a weighed string to get through the hole, then pull the cable through. An old plumb bob works well. I would recommend against running your antenna cable down the wall alongside an electrical cable as it's an easy way to introduce interference. I'd run them seperately, then bring them closer together at the wall point. DIY, Home Maintenance & Repair Are you doing this with a building permit? Conversion of a non habitable room into a habitable room requires building permit. 3 17280 I use Tramex moisture meter and it will tell me instantly if the wall is cement sheet or plaster or masonite but most people dont have the equipment. 5 7043 Hi All, I engaged a tradie to install concrete retaining wall 600-800mm high over 32 meters in Victoria. Sleepers are 200*75*2000 mm installed over 17 steel posts. I… 0 6829 |
