Browse Forums General Discussion 1 Dec 13, 2009 1:47 pm greetings all i am concidering raising the height of our garage door & belive the standard height of the opening is 2100mm & would like to increase this to allow us to get the Caravan through the Garage into the rear yard i belive the only way to do this is to have the floor in the Garage made lower - set into the ground further than the standard 90mm or so has anybody else done this & am i correct in beliveing thats how its done i would also be interested in hearing how any body else has accived a higher opening & what extra costs were involved cheers rocket Re: Garage Door Height - Lower Floor Level 2Dec 13, 2009 2:06 pm Isnt it that opposite? Raising the height of the garage entry? Otherwise the garage would flood Standard is 2100, one up from that is 2400. Ours is going to be 2700 Cant wait to see the cost of that! Custom European Cabinets - Melbourne Kitchen Specialist PM for business details as website currently being updated! Our Crazy Owner Builder Journey! Re: Garage Door Height - Lower Floor Level 3Dec 13, 2009 2:33 pm Bam Isnt it that opposite? Raising the height of the garage entry? Otherwise the garage would flood Standard is 2100, one up from that is 2400. Ours is going to be 2700 Cant wait to see the cost of that! sorry i dont follow what you mean there to make the garage door higher i dont belive that they lift the door up higher i thought that they dug the Garage slab down a little deeper & lifted the house slab up higher in doing this you require steps in the garage to access the house from the garage, in yur case i belive you will have a couple of steps cheers rocket Re: Garage Door Height - Lower Floor Level 4Dec 13, 2009 7:07 pm rodrocket - we have dropped our garage by 600mm, we have 2700mm ceilings, so this has made the garage in excess of 3mm tall. It's HUGE. The opening for the garage door is at least 3mtrs. So we are yet to see if they are going to put in a 3mtr high door or the standard 2700mm door with a lintel over it. Re: Garage Door Height - Lower Floor Level 5Dec 13, 2009 9:26 pm As we have 2.7 ceiling we lifted our door from 2100 to 2400 cost an extra $540 that was for the larger door. In our case it was the size of the lintel that changed not dropping the floor in the garage. In our previous home the garage slab was lower than the house slab by guessing about 100mm that was the standard when building. Cheers Lou http://take2-customdesigndownslope.blogspot.com 07-10-09 omg they have cut the block 14-05-10 we finally have the keys Hi there, We’ve recently had plans approved to add a 1st storey addition to our existing house for a growing family in Sydney. With the current cost of building… 0 4460 isn't a garage level with the rest of the house a given? pretty sure they 'came around' long time ago. if you have a flat block, the garage is usually level with the rest… 1 17695 I am looking to design an entry door to a lower ground basement that has 2200mm between the external entry height to FFL of the ground floor. This door will provide an… 0 12019 |
