Browse Forums General Discussion 1 Jul 17, 2007 8:29 pm Has anyone ever plastered over asbestos sheets?
Is there anything to consider when doing this? Re: Plastering - Asbestos 3Nov 26, 2007 1:44 pm Do you just mean gyprocking over the top?
Nothing special - just keep it in mind if your ever drilling into it. Plastering - Asbestos 4Nov 26, 2007 2:02 pm I was wanting to plaster using a gyprock basecoat between the asbestos sheet joints. This was preferred over placing a new gyprock sheeting over the asbestos.
I tried it with the paper tape and so far have had no cracking. Re: Plastering - Asbestos 6Nov 26, 2007 3:34 pm If your plastering skills are any good you don't even sand beyond the paint... I think fishing via a small hole may end up with big cut outs of gyrock, there are grey wires for smoke detectors just hanging.down so plasterers must be able to deal with… 3 1495 If this is a custom build then I would expect the builder to set out the door frame closer to the wall to avoid the gap between architrave and the wall and or specify… 9 3075 ![]() Neosdad, There is no right or wrong answer to your question, however one of the conditions of your CDC ( should you go that direction) will be to appoint a demo… 4 6373 ![]() |
