Browse Forums General Discussion 1 Dec 02, 2009 9:11 pm Hi everyone, Just looking for some collective wisdom, i've been reviewing the estate covenants (because well i have nothing better to do on a wednesday night ).we'll be building in Sandarra after the land is titled in Feb. It currently states * Side and boundary fences must be 1.5m in height above the natural ground level of the allotment and shall finish 1.0m behind the front building line to enhance the front facade. I'm querying this as must be 1.5m seems a little strange as no front fencing is allowed, and as they finish 1m from the front building line, are only going to be visible to neighbours, why wouldn't they be what i would consider the more standard 1.8m. Which is still below the 2m max legislated in victoria as the max without needing a permit. Anywho just looking for any comments or experience from others in new estates around Melbourne in relation to this, as to whether you've chosen an estate with a fixed fence height and any attached experiences. Cheers -Belial Our Build - Places Fairhaven 23+ - https://forum.homeone.com.au/viewtopic.php?f=31&t=28045 Our Landscaping - Belial's Backyard - https://forum.homeone.com.au/viewtopic.php?f=19&t=45375 Re: Estate Covenants - Specified Fence Heights 2Dec 02, 2009 9:47 pm 1.5m seems bizarre. We have covenants regarding fences, and ours must be 1.8m high, which is pretty standard for most areas. Even a short@rse like me could see over a 1.5m fence. You'd have no privacy whatsoever.... I'd query it with the developer. Re: Estate Covenants - Specified Fence Heights 3Dec 03, 2009 1:59 pm I thought our covenant was fussy, we have to 1.8meter high side & rear which must finish 1meter behind the front corner of the house made of treated and finished timber paling no colourbond allowed. 1.8 meter return at the front is only allowed if the fence is less than 2m otherwise a maxium hieght or 1.2m applies. If you want a front fence you need DAP approval, Thank god I don't have a golf course block there is even more rules..... Who comes up with all these rules... Cheers Lou http://take2-customdesigndownslope.blogspot.com 07-10-09 omg they have cut the block 14-05-10 we finally have the keys Re: Estate Covenants - Specified Fence Heights 4Dec 03, 2009 4:23 pm ours was equally silly. neighbour boundary had to be 1.8 and of the timber paling variety - no colourbond. as we were on a corner block there was even more rules ! Fence could only be solid for 50% of the length of the block. After that it had to be 50% see through. Fence could not come past front line of the house.. if it did it could only be 1m high or something ridiculous. no colorbond allowed on side return fencing either. Drove us mad trying to work it all out and find something not ugly that would fit the estate requirements. Re: Estate Covenants - Specified Fence Heights 5Dec 03, 2009 6:11 pm Received an email back from a contact we made at Clublinks whilst looking at swapping a crossover position. She's going to follow it up with the DAP to see if we need approval for a larger height or whether they will clarify the height. [JADED] neighbour boundary had to be 1.8 and of the timber paling variety - no colourbond. We're actually not fussed with it needing to be timber, not a fan of colourbond fencing myself and even less a fan of the hardiflex my sister's new fence is required to be made in over in WA. For anyone entirely board the full covenant (well the October version) is at http://www.sandarra.com.au/assets/design-guide.pdf The full fencing conditions are: 12. Side Fencing The detail of all fencing is to be included on your plans when submitted to the Design Assessment Panel. • Side and boundary fences must be 1.5m in height above the natural ground level of the allotment and shall finish 1.0m behind the front building line to enhance the front facade. • Fences between lots must be constructed of timber and exposed posts. All perimeter fencing must be completed prior to occupation of the dwelling. • The owner is solely responsible for the provision of maintenance and replacement of fencing between an allotment and any adjoining screening reserve or recreation reserve. • If an allotment already has a fence or wall being part of a fence or wall erected by the Developer, the owner must not remove damage or disfigure it and must maintain it in good condition. Any alteration of part of the wall or fence shall not be made without the Developer’s written permission. 13. Front Fencing Front fencing shall not be permitted on the front boundary or anywhere within the front yard. An alternative method of defining the edge of your property is the use of hedges, which should be in order of 1.2m in height on maturity. However the one covenant that really caused us the most grief was: The front setback is to be a minimum of 4.5 metres and maximum of 5 metres from the front boundary. When the front of our block is around 12m wide and the rear is 26wide and between 4.5->5m into the block its only about 13.5m wide, it rules out A LOT of current house designs as whilst we've been able to place the garage against one boundary we still required the council minimum setback from the opposite fence. What will be more interesting is seeing how our neighbors at the end of the court with the 8m frontage do, seeing as the garage must be set back from the front of the house. Anywho thats enough off topic ranting about covenant setbacks this is about fencing, uh i'm sure it is. Our Build - Places Fairhaven 23+ - https://forum.homeone.com.au/viewtopic.php?f=31&t=28045 Our Landscaping - Belial's Backyard - https://forum.homeone.com.au/viewtopic.php?f=19&t=45375 Re: Estate Covenants - Specified Fence Heights 6Dec 03, 2009 7:10 pm These people are selling narrow blocks and then forcing the buyers to have fences that give no privacy? I predict a sudden sprouting of cheap nasty treated pine (ugh!) fence extenders as soon as the developers move on. I used to think a few covenants would be a good thing to protect everyone's quality of life and investment, but I'm finding it quite astounding the sorts of things developers are inflicting on homebuyers. Re: Estate Covenants - Specified Fence Heights 7Dec 04, 2009 1:38 pm 1.5mtr is very short! I think they all specify a height but most will be 6' which is 1.83mtr. That's what mine is. Current build Porter Davis Brookwater 49, Eucalypt Wollert Build: 24th Jul 2015 - Approx Mar 2016 Previous build DFH Columbia 21, Lyndarum Epping North Build:20th Jul 2009 - 18th Dec 2009 Re: Estate Covenants - Specified Fence Heights 8Dec 09, 2009 2:01 pm Belial • Fences between lots must be constructed of timber and exposed posts. All perimeter fencing must be completed prior to occupation of the dwelling. well thats dumb.. what if your neighbour hasnt finished building.. and you want to split the cost of fence but cant get hold of them ? so you cant move in until its sorted? crazy times! Re: Estate Covenants - Specified Fence Heights 9Dec 10, 2009 4:51 pm Finally got a response back from C1ub1inks today. The maximum height allowed apparently is 1.8m so thats what i'll be having in our DAP submission. No comment was made as to the accuracy of the covenant. In regards to [JADED]'s comments above, pretty much our understanding is as apparently aside from us having to provide a cert of occupancy once its complete, we are to provide them an inspection to ensure compliance with the covenant. Ie that fences are built, roof colours match, its somewhat close to what was submitted. As to how and when and whats involved with that, i'm sure the intrepids who have just begun building in the titled stages will hit it first and let us all know how it goes (hopefully). Our Build - Places Fairhaven 23+ - https://forum.homeone.com.au/viewtopic.php?f=31&t=28045 Our Landscaping - Belial's Backyard - https://forum.homeone.com.au/viewtopic.php?f=19&t=45375 Re: Estate Covenants - Specified Fence Heights 11Dec 10, 2009 7:00 pm Ari Ours are 1.2m post and wire. Yes but are your neighbors houses located within 5-15m of your house? Our Build - Places Fairhaven 23+ - https://forum.homeone.com.au/viewtopic.php?f=31&t=28045 Our Landscaping - Belial's Backyard - https://forum.homeone.com.au/viewtopic.php?f=19&t=45375 Re: Estate Covenants - Specified Fence Heights 13Dec 11, 2009 7:50 am Ari Yes. 4 metre side setback THen the question must be asked, "Where on earth are you building?" and more to the point is it something your happy with? I'd also assume it would have to be a pet unfriendly estate. Care to elaborate? Our Build - Places Fairhaven 23+ - https://forum.homeone.com.au/viewtopic.php?f=31&t=28045 Our Landscaping - Belial's Backyard - https://forum.homeone.com.au/viewtopic.php?f=19&t=45375 Hi Everyone I learned something this week that I thought would be worth sharing. In NSW a lot of developers of subdivisions put covenants on the land which normally… 0 6550 Building Standards; Getting It Right! We bought a house in 2015 advertised as a 7/2/2, 4br up, 3br down (7br), and to date, it’s a great house. However, we’ve just had it valued and it’s come in as a… 0 11987 |
