Browse Forums General Discussion 1 Jul 15, 2007 12:56 pm The old man has just bought a new home in Melbourne with an inground pool he doesn't want.
He doesn't want to remove the pool but utilise it in a more suitable way. I suggested Barra, but he is is of the opinion that he can somehow use it as a water storage area, collecting run-off from the roof. The aim is to then have a removalable deck cover on which he can put an outdoor setting. I guess it needs to be sealed to keep out the mozzies etc. A kero film won't suit as the odur will ruin lunch. Is a bladder a viable option? What do you suggest? Re: The Old Man's pool 2Jul 15, 2007 2:03 pm Flyscreen mesh in fibreglass or stainless steel. you may need to join it as it is not so wide. "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: The Old Man's pool 3Jul 16, 2007 10:05 am I'd also put some sort of cover over it to stop sunlight otherwise it will be come an algle bloom in summer and a stagnant weed pond in winter.
Suggest you consider a deck over it (with the mesh underneath) so the area is useable and the water is in the dark and sealed below. Steve Is it possible to render an old corrugated iron shed.I have heard that it can be done if it is covered with chicken wire first.Not sure of the ratio of the render mix and… 0 4896 Thanks Chippy,I do have one that I levered out. I'll try to find a brand name on the windows then do some searching. Here is a photo where you can see how worn they are. 2 7959 Hi I bought an old cupboard that is in desperate need of some TLC. I was seeking some advice as to the best product to use to give it an oil but also bring it to life a… 0 3442 |
