Browse Forums General Discussion 1 Nov 28, 2009 8:35 am We are trying to pick our ceiling fans and are going to choose between a 3 and 4 bladed fan. But I don't know what the difference is. I assume it's probably efficiency but not really sure. Can anyone enlighten me please?? Thanks! Re: Ceiling Fan - 3 or 4 blades 2Nov 28, 2009 8:47 am I can't give you a technical answer, but I was told by the electrician that installed my air conditioning a few years ago that you should always look for 3 blades rather than 4. I think that metal is preferable to wooden blades, too. We have a wooden ceiling fan in our family room with 4 blades that tends to circulate warm air, rather than cool anything down. The 3 blade metal ceiling fan in our bedroom is much more effective and provides relief when the summer heat is unbearable overnight. Hope this helps! Re: Ceiling Fan - 3 or 4 blades 3Nov 28, 2009 4:26 pm Thanks Haven. I might see what they say in our fan shop. We'll definitely be getting metal though. Re: Ceiling Fan - 3 or 4 blades 4Dec 07, 2009 3:56 pm There is a new product called Fanaway - a clear acrylic blades of ceiling fan and the blades are concealed above the pendant light until the fan is switched on. Sounds interesting! Re: Ceiling Fan - 3 or 4 blades 5Dec 07, 2009 4:58 pm There was a discussion re this Fanaway, I will try to find it. edit - viewtopic.php?f=8&t=10473&hilit=fanaway www.themaxbuild.blogspot.com forum.homeone.com.au/viewtopic.php?f=31&t=20717&start=300 www.leahspaperpassion.blogspot.com Any electricians here please help. 1) Will the Fan need separate switch to ON/OFF/Speed eventhough it comes with Remote 2) how about… 0 1226 My home office is hot with computer equipment running virtually 18 hours a day. When it gets unbearably warm I simply step out of my door into the living area which is… 0 5130 How do you remove one of these ceiling air con vents? And is it possible to disconnect the duct joined to the vent from inside the house, without going into the roof cavity? 0 5947 |
